I'm struggeling a bit with the following case;
I want to have the last time a device is switch ON and in most case the last ON time is not equal to the lastUpdate property.
So I decided to save the Time() to an (global)data variable, but that isn't working.
Look like dzVents is not saving the Time() object when doing something like:
domoticz.globalData.BadkamerLastMotionOn = Time()
or
domoticz.data.BadkamerLastMotionOn = Time()
both variables are define in OR global_data.lua OR in the script itself.
Is this a known "bug" and/or has somebody an idea how to save the last ON time to persistent storage?
Persistent (global)data save Time()
Freemann
- Domoticz version: >=Béta
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Lubuntu 19.04,
HarmonyElite
IP-Cam
dannybloe
Re: Persistent (global)data save Time()
Don't save the Time object but just the raw value. If you use historical=true with persistence you automatic get a time stamp on your data. So, define your persistent variable with history = true and maxItems = 1 and simply store the state value in there. Then you can easily read the time stamp of the current value. Check the documentation about historical data.
Freemann
So easy... (zo simple)
Hero (HELD)!!
Hero (HELD)!!
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
Just for completeness; dzVents is capable of storing the time object in persistent storage.Freemann wrote: Monday 18 June 2018 12:30 I want to have the last time a device is switch ON and in most case the last ON time is not equal to the lastUpdate property.
So I decided to save the Time() to an (global)data variable.
or
... has somebody an idea how to save the last ON time to persistent storage?
see example code and resulting datafile
- Spoiler: show
- Spoiler: show
dannybloe
Yes but it is not needed as I explained above. You can however extract the raw time string and store that and feed that back into Time() when you need it again.
Freemann
So to "reuse" this topic;
Trying to make my variables global available, but not getting there.
how should I use the global define variables for getting/setting in my scripts?
Tried some variations like;
for setting:
I'm not getting the __data_global_data.lua to show data...
and should I define the global_data vars in my "local" scripts again?
[SOLVED] and maybe it can help somebody
found it after some "testing/debugging";
/home/user/domoticz/scripts/dzVents/scripts/global_data.lua looks like;
normal dzvents script is doing for historical setting;
normal dzvents script is doing for historical getting;
for setting:
domoticz.globalData.motionVar.add('Foo')
domoticz.globalData.motionVar = 'On'
domoticz.data.motionVar.add('Foo')
domoticz.data.motionVar = 'On'and should I define the global_data vars in my "local" scripts again?
data = {
LastMotionOn = { history = true, maxItems = 1}
}Code: Select all
domoticz.globalData.LastMotionOn.add('On')Code: Select all
domoticz.globalData.LastMotionOn.get(1).time.secondsAgoDomotica/graphs "freak" :)
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
