Page 1 of 2
World Cup Scoreboard - new version
Posted: Friday 15 June 2018 13:48
by elmortero
Not a real football fan myself but with the World Cup I make a little exception.
For that reason - and because I am always looking for data sources to play with the asynchronous http requests - I wrote this script.
The data are fetched from
http://worldcup.sfg.io/ and they offer other data sets. I was only interested in the status of the current game.
changed: now using the /today endpoint. This way at the end of the game the winner is displayed
In the code below I check if one of the teams is a team I want notifications about. If you don't want to use that remove line 30 to 32 and 47 to 49
timer = { 'every 2 minutes' },
httpResponses = { 'scoreboard2' } -- matches callback string below
execute = function(domoticz, triggerItem)
local board = domoticz.devices('Scoreboard2') --a virtual text sensor
local prevboard = tostring(board.text) --get current value of text sensor
if (triggerItem.isTimer) then
domoticz.openURL({
url = 'http://worldcup.sfg.io/matches/today',
method = 'GET',
callback = 'scoreboard2'
elseif (triggerItem.isHTTPResponse) then
local response = triggerItem
if (response.ok and response.isJSON) then
tl = #response.json
tc = 1
repeat
local status = tostring(response.json[tc].status)
local home = tostring(response.json[tc].home_team.country)
local away = tostring(response.json[tc].away_team.country)
local hgoal = tostring(response.json[tc].home_team.goals)
local agoal = tostring(response.json[tc].away_team.goals)
if away == 'Spain' or away == 'Belgium' or home == 'Spain' or home == 'Belgium' then
sender = true
show = (home..' '..hgoal..' - '..agoal..' '..away)
if status == 'in progress' then tc = tl + 1 end
if status == 'completed' then
local score = (hgoal..' - '..agoal)
local winner = tostring(response.json[tc].winner)
show = ('Match won by '..winner..' with '..score)
tc = tc + 1
if status == 'future' then tc = tl + 1 end
until tc > tl
if show ~= prevboard then
print ('result '..show)
board.updateText(show)
if sender then
--put your notification method here (mine is telegram)
print('**scoreboard2 failed to fetch info')
The attachment Capture.JPG is no longer available
Re: World Cup Scoreboard
Posted: Friday 15 June 2018 13:58
by jia175891641
good work!
Posted: Friday 15 June 2018 14:01
by ulisesrdg
Very useful!!!, Thank you for sharing!
Posted: Friday 15 June 2018 15:54
by elmortero
Found an error (needed a match in progress to test)
it should be: if #response.json > 0 then and not > 1
Posted: Saturday 16 June 2018 12:26
by EdwinK
- Screen Shot 2018-06-16 at 13.23.44.png (41.87 KiB) Viewed 3675 times
Thanks. I don't like soccer/football but this things are funny to play with.
Re: World Cup Scoreboard - new version
Posted: Sunday 17 June 2018 22:32
by corederoma82
how is the procedure for installation?
Posted: Sunday 17 June 2018 23:21
by EdwinK
Copy the lines of the scripts in the events editor, make sure to select dzVents.
Make a text device and name it scoreboard.
That's all
Posted: Monday 18 June 2018 13:49
by corederoma82
EdwinK wrote: Sunday 17 June 2018 23:21
That's all
Ok
Posted: Monday 18 June 2018 14:48
by CaesarPL
Thank you very much. Just curious - as I am still on last stable - will it work on old dzVents?
Posted: Monday 18 June 2018 15:06
by MikeF
I've just set this up as described, but I'm getting this dzVents error:
Error: dzVents: Error: ...omoticz/scripts/dzVents/generated_scripts/scoreboard.lua:11: attempt to index local 'triggerItem' (a nil value)
Posted: Monday 18 June 2018 19:18
by elmortero
MikeF wrote: Monday 18 June 2018 15:06
That means that you are on a dzVents version prior to 2.4
Posted: Monday 18 June 2018 19:54
by MikeF
Well, that's a shame - yes, I'm on version 2.2, with Domoticz stable 3.8153. I believe I would need to upgrade to Domoticz beta in order to get dzVents 2.4.
Posted: Monday 18 June 2018 20:45
by elmortero
MikeF wrote: Monday 18 June 2018 19:54
You should, there are some nice features in the later versions of dzVents.
Meanwhile, I took the time to make a pre-httpresponse version of the script. Should work, have not domoticz running on an older version to check all functions.
Try it if you want and let me know if it gives issues (the first time it runs you might get an error about the /tmp file not being available, on the second run it should be ok.
local scorefile = '/tmp/score.json'
local fetchIntervalMins = 3 -- interval to check the info (don't set to lower than 3)
active = true,
timer = { 'every minute' },
local callUrl = false
if (os.date('*t').min % fetchIntervalMins) == 0 then
callUrl = true
elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
return
local board = domoticz.devices('Scoreboard')
local linker = tostring('http://worldcup.sfg.io/matches/today')
if callUrl then
os.execute('curl -s "'..linker..'" > '..scorefile..'&')
print('json written to file')
return -- Nothing more to do for now, we'll be back in a minute to read the data!
local function readLuaFromJsonFile(fileName)
local file = io.open(fileName, 'r')
if file then
package.path = './scripts/lua/?.lua;'..package.path
local jsonParser = require('JSON')
local _json = file:read('*a')
local json = jsonParser:decode(_json)
io.close(file)
return json
return nil
local scoreData = readLuaFromJsonFile(scorefile)
if not scoreData then
print('** Scoreboard// Could not read scoreData from file: '.. scorefile)
return
tl = #scoreData
if tl > 0 then
tc = 1
repeat
local status = tostring(scoreData[tc].status)
local home = tostring(scoreData[tc].home_team.country)
local away = tostring(scoreData[tc].away_team.country)
local hgoal = tostring(scoreData[tc].home_team.goals)
local agoal = tostring(scoreData[tc].away_team.goals)
local winner = tostring(scoreData[tc].winner)
if winner == 'Draw' then
show = ('Draw '..home..' '..hgoal..' - '..agoal..' '..away)
tc = tc + 1
until tc > tl
Posted: Monday 18 June 2018 22:07
by LennartIsHigh
elmortero wrote: Monday 18 June 2018 20:45
I don't have a clue about what version I've got running but this version of yours works for me.
Posted: Monday 18 June 2018 23:39
by MikeF
Thanks for taking the time to do this - works well for me.
Posted: Tuesday 19 June 2018 11:07
by MikeF
I've made a change (to the pre-HTTPresponse version) to show kick-off time for future matches:
- Spoiler: show
active = true,
callUrl = true
return
if callUrl then
if file then
io.close(file)
return json
return nil
return
tl = #scoreData
if tl > 0 then
tc = 1
repeat
local date = tostring(scoreData[tc].datetime)
local pattern = "(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)"
local year, month, day, hour, minute, seconds = date:match(pattern)
hour = hour + 1
tc = tc + 1
show = (show..' KO '..hour..':'..minute)
tc = tl + 1
until tc > tl
Line 56 (hour = hour + 1) should be changed for different timezones (mine is UK BST).
Posted: Tuesday 19 June 2018 15:39
by MikeF
I've added the elapsed match time - although this will lag, as the script runs every 3 minutes:
- Spoiler: show
active = true,
callUrl = true
return
if callUrl then
if file then
io.close(file)
return json
return nil
return
tl = #scoreData
if tl > 0 then
tc = 1
repeat
local time = tostring(scoreData[tc].time)
hour = hour + 1
show = (show..' '..time)
tc = tl + 1
tc = tc + 1
tc = tl + 1
until tc > tl
Posted: Tuesday 19 June 2018 20:45
by freakshock
Thanks for the scripts elmortero & mike!
Posted: Friday 22 June 2018 19:04
by MikeF
I'm now getting this error when I run this (the pre-HTTPresponses version):
2018-06-22 18:01:04.516 Error: dzVents: Error: An error occured when calling event handler scoreboarrd
2018-06-22 18:01:04.516 Error: dzVents: Error: Lua script execution exceeds maximum number of lines
Any clues? Is it looping (more than it should!)?
Posted: Friday 22 June 2018 19:22
by MikeF
There are problems with the feed today. The matches are in the wrong order, with the wrong times, and the 3rd match (which appears second) is showing a status of 'pending correction' - which the dzVents script doesn't recognise.
