Heiman Smart Smoke Sensor HS1SA-Z+
Posted: Tuesday 12 June 2018 16:54
by FuTuReD
I have bought the cheap Heiman Smart Smoke Sensor HS1SA-Z+. In the OZW config I see the Node:
smoke dtector.JPG (59.17 KiB) Viewed 2258 times
But Domoticz does not create a device with IDX number. What's going wrong?
Does domoticz not support this Smoke Sensor?
Re: Heiman Smart Smoke Sensor HS1SA-Z+
Posted: Tuesday 12 June 2018 18:34
by LouiS22
FuTuReD wrote: Tuesday 12 June 2018 16:54 I have bought the cheap Heiman Smart Smoke Sensor HS1SA-Z+. In the OZW config I see the Node:
Have you enabled the create new device at Settings? Also, push the test button to create an event (beware, it's going to be loud :D).
Posted: Tuesday 12 June 2018 21:37
by FuTuReD
Thank you @louiS22!! I have enabled "adding devices" and give a restart of Domoticz and yes the smoke detector appears as new device.
