Heiman Smart Smoke Sensor HS1SA-Z+ Topic is solved
FuTuReD
Post by FuTuReD »
I have bought the cheap Heiman Smart Smoke Sensor HS1SA-Z+. In the OZW config I see the Node:
smoke dtector.JPG (59.17 KiB) Viewed 2015 times
But Domoticz does not create a device with IDX number. What's going wrong?
Does domoticz not support this Smoke Sensor?
LouiS22
Re: Heiman Smart Smoke Sensor HS1SA-Z+
Post by LouiS22 »
FuTuReD wrote: Tuesday 12 June 2018 16:54 I have bought the cheap Heiman Smart Smoke Sensor HS1SA-Z+. In the OZW config I see the Node:
Have you enabled the create new device at Settings? Also, push the test button to create an event (beware, it's going to be loud :D).
FuTuReD
Post by FuTuReD »
Thank you @louiS22!! I have enabled "adding devices" and give a restart of Domoticz and yes the smoke detector appears as new device.
