Hi, i currently run Domoticz "Beta" on my Rasp 3B+. I can reach it from the browser 192.168.1.38:8080
But now I want run Domoticz "Stable" on my Rasp 3B+
When I want to run the Domoticz "stable" version, I can't reach it from the browser 192.168.1.38:8080
How to fix this problem?
Install Domoticz on Rasp 3B+
Koensk
Re: Install Domoticz on Rasp 3B+
Hi there,
I have the same problem and I can't find the solution.
How can I do a clean install that will actually work?
Thanks anyone for your help
jornm
Open a terminal and run:
This should give this output:
Note that the 3463 is process id and will change
If you do not get any output domoticz is not running/listening
sudo netstat -lpn | grep 8080
tcp6 0 0 :::8080 :::* LISTEN 3463/./domoticz
