at Sunrise and at Sunset not working?
RoRoo
Post by RoRoo »
Hi all!
I've been trying to get my script working correctly, but strangely enough, my script isn't getting started.
I currently have this code:
	active = true,
		timer = {
			'at Sunset',
            'at Sunrise'
	execute = function(domoticz, device, triggerInfo)
	    local AchterTuin_Licht = domoticz.devices('Sonoff_Tuinlicht')
	    local Voortuin_Licht = domoticz.devices('Buitenlamp_Voor')
	    if (triggerInfo.trigger == 'at Sunset')
	    then
		    AchterTuin_Licht.switchOn().withinMin(15)
		    Voortuin_Licht.switchOn().withinMin(15)
		    domoticz.log('Sunset, tuinverlichting gaat random aan binnen 15 minuten.');
		    domoticz.notify('Domoticz Notification', 'Sunset, tuinverlichting gaat random aan binnen 15 minuten.', 'domoticz.PRIORITY_NORMAL')
		elseif (triggerInfo.trigger == 'at Sunrise')
		then
		    AchterTuin_Licht.switchOff().withinMin(15)
		    Voortuin_Licht.switchOff().withinMin(15)
		    domoticz.log('Sunrise, tuinverlichting gaat random uit binnen 15 minuten.');
		    domoticz.notify('Domoticz Notification', 'Sunrise, tuinverlichting gaat random uit binnen 15 minuten.', 'domoticz.PRIORITY_NORMAL')
When I change "at Sunset" to "at NightTime" and "at Sunrise" to "at Daytime" the script works and the lights switch on, but I get my Notification and Log entry every minute..
Am I missing something for the sunset and sunrise to work?
My location has been set in Domoticz and I can see the sunset and rise times.
Version information:
Version: 3.9530
Build Hash: 30295913
Compile Date: 2018-05-29 14:27:24
dzVents Version: 2.4.6
Python Version: 3.5.3 (default, Jan 19 2017, 14:11:04) [GCC 6.3.0 20170124]
b00p
Re: at Sunrise and at Sunset not working?
RoRoo wrote: Saturday 09 June 2018 22:47 I've been trying to get my script working correctly, but strangely enough, my script isn't getting started.
		timer = {  'at Sunset',  'at Sunrise' } },
I have not tested it but at first glance it looks like it has something to do with the use of uppercase in your timer settings.
You should use 'at sunset', 'at sunrise'
RoRoo
Post by RoRoo »
Could it be thát stupid? The DZVents editor autofills with a capital, but I can't remember if I've tested it without...
I'll change it. Thanks for the tip!
b00p
dannybloe
Post by dannybloe »
Yes, it is that stupid. Case sensitive it is.
RoRoo
Post by RoRoo »
dannybloe wrote: Sunday 10 June 2018 15:43 Yes, it is that stupid. Case sensitive it is.
Such a simple error that had me tinkering for days :)
I trust my lights will go on this evening.
The autofill in the editor was filling Sunrise due to my notification text. I've mistaken it for feature filling.
b00p
