DzVents script for bathroom lights
snellejellep
Post by snellejellep »
Dear all,
i started using dzvents and it is really nice once you get the logic in your head, i created a script which would turn on my bathroom lights (Group badkamer boven = the name in the script) when my motion sensor(PIR badkamer boven = the name in the script) is triggered or when there is water in the shower(Water douche boven = the name in the script). it works well but i had something in my blockly which i was using before where i could check the lux value of my motionsensor and act upon it, also i had time values for example before 23:00 set light to 100% after 23:00 set light at 40% but only if the shower is off. and this all if the lux value was below 30
while i think dzvents would be a much better solution then my 4 combined blockly scripts which stopped magically working i can not seem to find out from the documentation or the awesome getting started video how to get the above functions in my script. so if someone can help me, please... also, do not laugh at my basic level of dzvents plz XD
		devices = {
			'Water douche boven',
			'PIR badkamer boven',
			'licht tk was aan'
		if(device.state == 'On') then
		    local badkamer = domoticz.devices('Group badkamer boven').dimTo(100)
		    badkamer.switchOn()
		    badkamer.switchOff()
Re: DzVents script for bathroom lights
Could be something like this:
--[[ ShowerTest.lua for
        devices = {
            "Water douche boven",
            "PIR badkamer boven",
            "licht tk was aan",
    execute = function(dz, device)
        local luxLevel      = dz.devices("motion sensor").lux
        local shower        = dz.devices("water douche boven").state
        local badkamerLicht = dz.devices("Group badkamer boven")
        local lightStrength = 100
        if (dz.time.matchesRule("at 23:00-23:59") or dz.time.matchesRule("at 00:00-08:00")) and shower.state == "Off"  and luxLevel < 30 then
            lightStrength = 40
        if(device.state == "On") then
            badkamerLicht.dimTo(lightStrength)
            badkamerLicht.switchOff()
snellejellep
wow, thanks again!
this is an amazing start, now i just have to figure out how to let the lights stay on for two minutes or something like that when motion was triggered because that hue motion sensor is really sensitive, when you stand still it immediately stops saying that there is motion and flickering lights are a bit anoying :)
but this is really amazing, i hope you did not only help me but also others who are searching for something similar
snellejellep wrote: Thursday 07 June 2018 8:10
.. now i just have to figure out how to let the lights stay on for two minutes or something like that when motion was triggered because that hue motion sensor is really sensitive, when you stand still it immediately stops saying that there is motion and flickering lights are a bit anoying :)
but this is really amazing, i hope you did not only help me but also others who are searching for something similar..
To give an idea how to solve this; added a minimum of 2 minutes between switch "On" and - "Off"
--[[ ShowerTest.lua
        devices = {
            "licht tk was aan"
    logging =   {   level     =   domoticz.LOG_DEBUG,
                    marker    =   "ShowerTest" },
    execute = function(dz, trigger)
            lightStrength = 40
        if trigger.state == "On"  then
            if badkamerLicht.level ~= lightStrength then
        elseif badkamerLicht.lastUpdate.minutesAgo > 2 then
            dz.log("No action now. " .. badkamerLicht.name ..
                " switched to \"" .. badkamerLicht.state ..
                "\" " .. badkamerLicht.lastUpdate.secondsAgo ..
                " seconds ago.",dz.LOG_DEBUG)
snellejellep
waaren wrote: Thursday 07 June 2018 8:59
wow, amazing! cant thank you enough!
bozidar
Post by bozidar »
Hi snellejellep
Still new to domoticz wondering how do domoticz know shower is on
snellejellep
@bozidar, i use a xiaomi gateway with water sensor, those sensors are really small and fit in the thingy the water flows to (drain?)
links:
gateway: https://www.gearbest.com/living-applian ... id=1433363
sensor: https://www.gearbest.com/home-smart-imp ... id=1433363
other compatible stuff: https://www.domoticz.com/wiki/Compatibl ... n_gearbest
rrozema
Post by rrozema »
--[[ ShowerTest.lua
        devices = {
            "licht tk was aan"
            lightStrength = 40
Since this script is only triggered by 3 device triggers, how do you make it so that
gets executed at some time > 2 minutes after the light is no longer on?
snellejellep
--[[ ShowerTest.lua
        devices = {
            "licht tk was aan"
            lightStrength = 40
I ran in to that problem myself so i added a five minute timer as an extra trigger. So it gets triggered every five minutes to check if the lights still need to be on
rrozema
Post by rrozema »
ah, thanks. I was wondering if I had overlooked something :-) I have a separate, generic script called "Auto Off" that gets executed once a minute to check for devices that need to be switched off. This way I can keep the scripts to switch things on simple.
rogzon
Post by rogzon »
In the off event for the PIR you could put domoticz.devices('bathroom lights name').switchOff().afterMin(2) which would switch off lights two minutes after PIR has reported no motion. You then need to put domoticz.devices('bathroom lights name').cancelQueuedCommands() in PIR On event otherwise it will switch off no matter if PIR has detected motion or not.
pvm
Domoticz version: 4.10538
Post by pvm »
snellejellep wrote:@bozidar, i use a xiaomi gateway with water sensor, those sensors are really small and fit in the thingy the water flows to (drain?)
Brilliant idea, thnx! Nice solution for switching ventilation
