My very first Dzventz "script" please help
Posted: Tuesday 05 June 2018 16:29
by bozidar
Hi all
I am trying to make a very simple "script"
I want a specific wallswitch to turn on/off a light.
1436 is wallswitch idx and 1424 is light idx.
What have i done wrong ?
devices = {
'1436'
execute = function(domoticz,'1424')
local Living room = domoticz.devices('1424')
domoticz.ToggleSwitch ()
Re: My very first Dzventz "script" please help
Posted: Tuesday 05 June 2018 18:25
by waaren
Something with quotes and syntax. Try it like this
--[[ toggler.lua
on = { devices = { 1436 }}, -- Trigger = Switch device IDX
execute = function(domoticz,trigger)
local livingRoom = domoticz.devices(1424) -- Light IDX
livingRoom.toggleSwitch()
Posted: Tuesday 05 June 2018 18:55
by bozidar
thx very appreciated.
But there seems to be a litle bug in it.
Light turn on 2 sec and then turns of.
Posted: Tuesday 05 June 2018 19:11
by bozidar
Hold on.
I believe that nothing is wrong with you script.
Posted: Tuesday 05 June 2018 20:54
by bozidar
Thx again waaren
But realized that my actual lightswitch is not a on/off switch.
It is a "digital switch" sending a ON signal when pressed ,and is in "off" state when not pressed.
which makes using the toggle function a bad idea.
So i guess it needs to be done in a complete different way.
Any ideas ?
Posted: Tuesday 05 June 2018 22:43
by waaren
bozidar wrote: Tuesday 05 June 2018 20:54
Realized that my actual lightswitch is not a on/off switch.
Not a COMPLETE different way. Just a check on the state of the "trigger state" should do it.
--[[ Toggler.lua
logging = { level = domoticz.LOG_DEBUG,
marker = "Toggler" },
if trigger.state == "On" then
domoticz.log("Trigger state ==>> " .. trigger.state .. "; Light state ==>> " .. livingRoom.state ,domoticz.LOG_DEBUG)
Posted: Wednesday 06 June 2018 9:27
by McMelloW
Perhaps this video might be some help
viewtopic.php?f=59&t=18143
Posted: Wednesday 06 June 2018 17:58
by bozidar
Thank you Mcmellow
Belive it or not ,but have seen that video at least 5 times.and read the manual ..
But with no coding experience ,and limited Domoticz skilled ,the first steps are just so much harder.
I have learned so much over the last year ,but are also spending much more time than ,the more experience person.
But thx for the help and hints...
Moving forward ,but very slowly.
Posted: Wednesday 06 June 2018 20:28
by bozidar
hi again
Shouldn't this work then : just turning on a gruop of lights instead of 1 light.
--[[ Toggler.lua
on = { devices = { 1439 }}, -- Trigger = Switch device IDX
local livingRoom = domoticz.group(1) -- Light IDX
livingRoom.toggleGroup()
Hopefully last ??
Thxalot for the help
Posted: Wednesday 06 June 2018 22:55
by waaren
syntax is domoticz.groups ; You forgot the s
Posted: Thursday 07 June 2018 16:59
by bozidar
Exelent
thank you Waaren. Help is really much apreciated.
