My very first Dzventz "script" please help
bozidar
Hi all
I am trying to make a very simple "script"
I want a specific wallswitch to turn on/off a light.
1436 is wallswitch idx and 1424 is light idx.
What have i done wrong ?
devices = {
'1436'
execute = function(domoticz,'1424')
local Living room = domoticz.devices('1424')
domoticz.ToggleSwitch ()
devices = {
'1436'
- waaren
Re: My very first Dzventz "script" please help
Something with quotes and syntax. Try it like this
--[[ toggler.lua
on = { devices = { 1436 }}, -- Trigger = Switch device IDX
execute = function(domoticz,trigger)
local livingRoom = domoticz.devices(1424) -- Light IDX
livingRoom.toggleSwitch()
}Debian buster, bullseye on RPI-4, Intel NUC.
bozidar
thx very appreciated.
But there seems to be a litle bug in it.
Light turn on 2 sec and then turns of.
bozidar
Hold on.
I believe that nothing is wrong with you script.
bozidar
Thx again waaren
But realized that my actual lightswitch is not a on/off switch.
It is a "digital switch" sending a ON signal when pressed ,and is in "off" state when not pressed.
which makes using the toggle function a bad idea.
So i guess it needs to be done in a complete different way.
Any ideas ?
Any ideas ?
- waaren
Not a COMPLETE different way. Just a check on the state of the "trigger state" should do it.bozidar wrote: Tuesday 05 June 2018 20:54 Realized that my actual lightswitch is not a on/off switch.
--[[ Toggler.lua
logging = { level = domoticz.LOG_DEBUG,
marker = "Toggler" },
if trigger.state == "On" then
domoticz.log("Trigger state ==>> " .. trigger.state .. "; Light state ==>> " .. livingRoom.state ,domoticz.LOG_DEBUG)
- McMelloW
- Domoticz version: V2024.1
Perhaps this video might be some help
viewtopic.php?f=59&t=18143
Greetings McMelloW
bozidar
Thank you Mcmellow
Belive it or not ,but have seen that video at least 5 times.and read the manual ..
But with no coding experience ,and limited Domoticz skilled ,the first steps are just so much harder.
I have learned so much over the last year ,but are also spending much more time than ,the more experience person.
But thx for the help and hints...
Moving forward ,but very slowly.
bozidar
hi again
Shouldn't this work then : just turning on a gruop of lights instead of 1 light.
--[[ Toggler.lua
on = { devices = { 1439 }}, -- Trigger = Switch device IDX
local livingRoom = domoticz.group(1) -- Light IDX
livingRoom.toggleGroup()
Hopefully last ??
Thxalot for the help
--[[ Toggler.lua
Hopefully last ??
- waaren
syntax is domoticz.groups ; You forgot the s
bozidar
Exelent
thank you Waaren. Help is really much apreciated.
