Anyone been able to get a Nuaire Drimaster passive ventilation unit linked to an RFlink?
I have a 433mhz link RFlink, but cant see any signals from the Drimaster remote switches to the unit, so I presume it works on 868mhz?
There's virtually no information about radio signals on manufacturers website
Nuaire Drimaster Eco-Heat-HC & RFlink?
DanM
Re: Nuaire Drimaster Eco-Heat-HC & RFlink?
Replying after a long time.. but did you ever make progress with this? Its definately 868 - I spoke to the company about it. I was thinking of buying one of the switches and just soldering to it to send the signals..
gwaelod
No - not fiddled with it very much apart from pulling open the switch and noting that it looks virtually identical to the Orcon sensor in this thread
viewtopic.php?f=49&t=13713
Browsing some dutch forums the electronics superficially resemble some other dutch ventilation systems (Itho)
gwaelod
When you say soldering to it send signals..do you mean soldering something like an ESP8266 to it and using the outputs to drive the switches?
This RF (868 Mhz) system uses the Residential Network Protocol. This includes the Nuaire 4-way switch, and other kit.
Raw packet from humidity sensor:
Decoded packet:
Decoded payload (003C07A8049C):
You could calculate a higher-precision relative humidity from the other two values using any one of the known formula.
The python code to take the raw payload and create the JSON is:
045 I --- 32:168090 --:------ 32:168090 12A0 006 003C07A8049CCode: Select all
|| 045 | I | | 32:168090 | | >broadcast | sensor_humidity | 006 | 003D07B304B9 ||Code: Select all
{'domain': '00', 'relative_humidity': 0.61, 'temperature': 19.71, 'dewpoint': 12.09}The python code to take the raw payload and create the JSON is:
"domain": payload[:2],
"relative_humidity": int(payload[2:4], 16) / 100,
"temperature": int(payload[4:8], 16) / 100,
"dewpoint": int(payload[8:12], 16) / 100,
If anyone has information on the residential network protocol, please PM me!
