So if you compile locally V3.9530 or higher then first check if you have chrono in your boot library.
On debian stretch you can use the following command for that check.
sudo dpkg --list | grep chronoModerator: leecollings
sudo dpkg --list | grep chronoUsers browsing this forum: No registered users and 1 guest
