Transmit undecoded ARC
Venzent
Domoticz version: 3.8153
Post by Venzent »
I've just received my RFXcom 433 rtxrfx and am trying to transmit my doorbell code (unknown brand).
I enabled undec and ARC and can capture the signal:
Packettype = UNDECODED RF Message
UNDECODED ARC:305D75D59307DB
As I understand from the manual, I should be able to transmit this code with the given HEX table. Only they use an example of 6 numbers giving the 24 HEX position.
So, how do I translate my captured code to use on Lighting4?
b_weijenberg
Re: Transmit undecoded ARC
Post by b_weijenberg »
What is received in RFXmngr if you disable ARC and enable only Lighting4?
RFX-433, RFX-433EMC, RFX-868
Venzent
Post by Venzent »
b_weijenberg wrote: Wednesday 30 May 2018 11:15 What is received in RFXmngr if you disable ARC and enable only Lighting4?
Then it is not detected....
I really don't need to transmit it, it is more a test on how it works with the protocols.
But is it possible to trigger something based on this undecoded ARC message in Domoticz?
florfilla19
Domoticz version: 4.10717
Post by florfilla19 »
Hello, same issue here with my RFXtrx433XL
and ZIGLINT Doorbell from Amazon
UNDECODED ARC:28355C880403
Any help is welcome, would like to receive a mail when somebody is ringin at the door
b_weijenberg
