I'm best to create a new thread for this remote, it is basically like the Aeon Wallmote, however something seems different on the configuration. I have looked at the one from Aeon:
<Product type="0002" id="0082" name="ZW130 WallMote Quad" config="aeotec/zw130.xml"/>
Does any one knows how to create the config file from these parameters:
http://manuals-backend.z-wave.info/make ... 0-17045535
As per this, I should be able to do it if I understand it first
How do I go from the pages above to create a file like this?
<?xml version="1.0" encoding="utf-8"?>
Aeotec ZW130 WallMote Quad, base on Engineering Spec 9/27/2016
<Product xmlns='http://code.google.com/p/open-zwave/'>
<!-- COMMAND_CLASS_BASIC -->
<CommandClass id="32" getsupported="false"/>
<!-- COMMAND_CLASS_SWITCH_BINARY -->
<CommandClass id="37" getsupported="false"/>
<!-- COMMAND_CLASS_SWITCH_MULTILEVEL -->
<CommandClass id="38" getsupported="false"/>
<!-- Configuration Parameters -->
<CommandClass id="112">
<Value type="list" genre="config" instance="1" index="1" label="Touch sound" min="0" max="1" value="1" size="1">
<Help>This will enable or disable the sound effects when you press or touch the sensing area</Help>
<Item label="Disable" value="0"/>
<Item label="Enable" value="1"/>
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Touch vibration" min="0" max="1" value="1" size="1">
<Help>This will enable or disable the vibration effects when you press or touch the sensing area</Help>
</Value>
<Value type="list" genre="config" instance="1" index="3" label="Button slide function" min="0" max="1" value="1" size="1">
<Help>This will enable or disable control by sliding the button area</Help>
</Value>
<Value type="list" genre="config" instance="1" index="4" label="Report type" min="0" max="1" value="1" size="1">
<Help>To configure which report will be sent when pressing the buttons</Help>
<Item label="Send nothing" value="0"/>
<Item label="Send Central Scene Command Notification" value="1"/>
<Item label="Send Central Scene Command Notification and Configuration report" value="3"/>
</Value>
<Value type="int" index="5" genre="config" label="Color when button is pressed" units="" value="65280" >
<Help>
To configure which color will be displayed when the button is pressed.
Value 1: (msb) Red.
Value 2: Green.
Value 3: Blue.
Value 4: Reserved
</Help>
</Value>
<Value type="int" index="33" genre="config" label="Test the LED, buzzer and vibrator" units="" value="0" read_only="true">
<Help>
Get the LED Strip color value
Value 1: (msb) Red.
Value 2: Green.
Value 3: Blue.
Value 4: buzzer and vibrator. (1=ON, 0=OFF)
</Help>
</Value>
<Value type="byte" index="39" genre="config" label="Set the low battery value" units="%" min="10" max="50" value="20">
<Help>
Set the low battery value.
Range: 10% - 50%.</Help>
</Value>
<Value type="list" index="255" genre="config" label="Reset To Factory Defaults" size="4" value="1" write_only="true">
<Help>Reset to factory defaults</Help>
<Item label="Reset to factory default setting" value="0"/>
<Item label="Normal" value="1"/>
<Item label="Reset to factory default setting and removed from the z-wave network" value="1431655765"/>
</Value>
</CommandClass>
<!-- Association Groups -->
<CommandClass id="133">
<Associations num_groups="9">
<Group index="1" max_associations="1" label="Lifeline"/>
<Group index="2" max_associations="5" label="On/Off control via Button 1"/>
<Group index="3" max_associations="5" label="Dimmer control via Button 1"/>
<Group index="4" max_associations="5" label="On/Off control via Button 2"/>
<Group index="5" max_associations="5" label="Dimmer control via Button 2"/>
<Group index="6" max_associations="5" label="On/Off control via Button 3"/>
<Group index="7" max_associations="5" label="Dimmer control via Button 3"/>
<Group index="8" max_associations="5" label="On/Off control via Button 4"/>
<Group index="9" max_associations="5" label="Dimmer control via Button 4"/>
</Associations>
</CommandClass>
<!--<CommandClass id="142" ForceInstances="true"/>-->
</Product>
https://www.amazon.co.uk/WALLMOTE-WIREL ... ords=domux
