EventSystem: reset all events...
Posted: Sunday 13 May 2018 12:02
by fabiorodo
after using a domoticz on rpi just for danfoss (with blocky events) on heaters I decided to add more pieces.
I started with a fresh install but every try on events gives me:
and nothing happens.
I tried several tests mostly really easy like
if time= xx:xx
then turn on light / close shutter
write xxx on log
Right now I have the last beta on rpi3 V3.9426
connected to domoticz I have:
a xwave system with multiple fgr222 a fibaro multisensor and the danfoss
a xiaomi gateway with temperature and leak sensors
a hue hub with mixed hue and tradfri lights.
any suggestions?
what should I check?
Re: EventSystem: reset all events...
Posted: Saturday 19 May 2018 10:35
by cogliostrio
This log message only tells you that the eventsystem has been restarted, because you have saved a new event in the editor.
fabiorodo wrote: Sunday 13 May 2018 12:02
Can you switch the system manually from the web interface?
Posting your blockly will probably help as well.
Posted: Monday 21 May 2018 18:36
by fabiorodo
thank you for your reply.
this is the blocky:
- FireShot Capture 20 - CasaErreTi - http___192.168.178.44_8080_#_Events.png (14.45 KiB) Viewed 3645 times
the event is active and saved.
scrivania is a light switch but i also tried several others.
when i check the current status i get this:
Error getting current states, Is the Eventsystem Enabled?
the boxes in settings are unchecked so should be enabled.
any help is more than welcome.
f
Posted: Monday 21 May 2018 19:28
by SweetPants
fabiorodo wrote: Monday 21 May 2018 18:36
Are you sure that means enabled? They should be green
Posted: Monday 21 May 2018 19:44
by lmet
Under Setup->Settings->Others, Is the EventSystem enabled ?
Posted: Monday 21 May 2018 23:22
by fabiorodo
Hi to all,
this is what I have...
I found different pics in the forum.
but with both chrome and firefox in linux mint i get this.
- FireShot Capture 24 - CasaErreTi - http___192.168.178.44_8080_#_Setup.png (23.69 KiB) Viewed 3616 times
thanks for support
f
Posted: Tuesday 22 May 2018 12:59
by SweetPants
Are you sure you are running V3.9426? Then dzVents should be V2.4.5. I think you still have a application cache problem. Please clear your browser and application cache first (both are different things)
Posted: Sunday 27 May 2018 18:38
by fabiorodo
Hi All,
thanks for your suggestions. I solved using Opera from mobile. even if I deleted the browser cache many times something was going wrong. events where disabled (in firefox and chrome the box was really confusing). right now I am trying to clean the app cache.
Thanks again
Posted: Tuesday 29 May 2018 7:41
by SweetPants
fabiorodo wrote: Sunday 27 May 2018 18:38
Hi All,
Thanks again
As said before you should clear your browser
and application cache. The application cache is holding the old .js scripts hence the old data you see
