Domoticz opens firefox at startup
Skwi
Post by Skwi »
Hi, I'm new on domoticz and I installed it on my Windows 10 (as an app not service if that can help).
When I start my computer now, firefox (default nav) starts too on the domoticz page plus makes freeze firefox and I have to kill it in the task mgr.
I couldn't find in the parameters where I can disable that behaviour. An idea?
SweetPants
Re: Domoticz opens firefox at startup
Post by SweetPants »
This is not a domoticz thing but a browser/OS issue.
gordonb3
Domoticz version: Custom
Post by gordonb3 »
if you had run `domoticz /?` you would have found there is a command line switch to disable automatic browser startup.
Skwi
Post by Skwi »
SweetPants wrote: Thursday 10 May 2018 10:56 This is not a domoticz thing but a browser/OS issue.
Before I installed domoticz my browser didn't start when my computer turn on, so it's directly linked to domoticz (plus my default web page isn't domoticz)
gordonb3 wrote: Thursday 10 May 2018 11:14 if you had run `domoticz /?` you would have found there is a command line switch to disable automatic browser startup.
Where can I run such a command on windows? This is not a recognised command, maybve I need to add a varaible path but I don't know which one.
Ok so I find out how to do so on Windows :
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
Edit the properties and add in target :
"C:\Program Files (x86)\Domoticz\domoticz.exe" -startupdelay 10 -www 8080 -sslwww 443 -nobrowser
(found the option on this thread : http://www.domoticz.com/forum/viewtopic.php?t=13141)
gordonb3
Post by gordonb3 »
You would have to run that previously mentioned command in the scary black screen that only (very) old people know how to work with ;)
Skwi
Post by Skwi »
gordonb3 wrote: Thursday 10 May 2018 18:07 You would have to run that previously mentioned command in the scary black screen that only (very) old people know how to work with ;)
If you are talking about windows cmd I of course did try it. I get in the right folder but when I run "domoticz /?" nothing is displayed and domotic just start as usual. If you are talking about another console specific to domoticz I don't know where I can find that (I can only show/hide display console but cannot type anything in it)
gordonb3
Post by gordonb3 »
That's not what you posted before. You said it was `not a recognised command`
In any case, the `/?` should have given you the help screen on Windows. If it didn't I don't know why. Alternate parameters for displaying the help screen are `-h` or `--help`
Skwi
Post by Skwi »
Yeah, not a recognised command, but how would I have this information if I didn't tried this in a console? :/
For more details, if I open cmd in windows and type only "domoticz" with any command (/? -h -help etc.) I got this :
C:\Users\Skwi>domoticz /?
'domoticz' n’est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
If i go in the folder where domoticz is installed if domoticz is off it just turns on without any information in cmd (even with /?)
If it's on I got : Another instance of Domoticz is already running!
It's probably a windows issue for not getting the help with this cmd, I need to install domoticz on my rpi anyway.
gordonb3
Post by gordonb3 »
All I can say is that it should display the help and finish. If it doesn't I don't know why. Also, the nobrowser option is Windows only so you will not see that when running it on a Pi or other Linux machine.
