Fire TV Status
All kinds of 'OS' scripts
DanM
Fire TV Status
Post by DanM »
Figured I'd share my fireTV status script. To run the script you need ADB tools installed as this is how the pi connects to the stick. It triggers a selector switch via curl so you need to alter the urls and the device IDs etc to make it work.
#!/bin/bash
adb kill-server
adb start-server
adb connect IP_OF_FIRETV
#I like to see the output when I run from the command line, helps to identify the IDs of new apps.
adb shell dumpsys activity recents |grep "Recent #0"
playing="$(adb shell dumpsys activity recents |grep "Recent #0")"
if [[ $playing = *"iplayer"* ]]; then
state="STATE_ON_IPLAYER"
fi
if [[ $playing = *"kodi"* ]]; then
state="STATE_ON_KODI"
fi
if [[ $playing = *"netflix"* ]]; then
state="STATE_ON_NETFLIX"
fi
if [[ $playing = *"disney"* ]]; then
state="STATE_ON_DISNEY"
fi
if [[ $playing = *"amazon.avod"* ]]; then
state="STATE_ON_AMAZON"
fi
if [[ $playing = *"launcher"* ]]; then
state="STATE_ON_LAUNCHER"
fi
adb shell dumpsys power | grep "Display Power"
playing="$(adb shell dumpsys power | grep "Display Power")"
if [[ $playing = *"state=OFF"* ]]; then
state="STATE_OFF"
fi
#This echo isnt needed but useful to keep track when running from command line.
echo $state
#Splitting the script into two like this doesnt do much in this implementation. It is done this way because I feed in other devices (such as the actual television power status) and have more complex logic than shown below.
case $state in
"STATE_ON_NETFLIX")
curl 'http://192.168.0.1:8080/json.htm?type=command&param=switchlight&idx=XXXXX&switchcmd=Set%20Level&level=XXX'
"STATE_ON_LAUNCHER")
"STATE_ON_AMAZON")
"STATE_OFF")
"STATE_ON_KODI")
"STATE_ON_DISNEY")
"STATE_ON_IPLAYER")
esac
adb disconnect
Loky31
Re: Fire TV Status
Post by Loky31 »
Nice script to reflect firetv statuts 😉
Looking at thé script i guess it Is not intended to Control firetv, By any chance would you be able to show à command line that can Control thé firetv ?
What I'm Looking for Is à Way to wake it up and at least make a pause/play command on it.
It would be really great if you can give me a hand on that 😁
Many Thanks in avance
alanlsmith
Domoticz version: Latest β
Re: Fire TV Status
Post by alanlsmith »
This bash script will start a Fire TV box. 'keyevent' 26 is the command to wake it up. and the next line starts the BBC iPlayer (so can be ignored or changed to an app of your choice.
#!/bin/bash
adb start-server && \
adb connect <IP address of Fire TV> && \
sleep 0.5 && \
adb shell input keyevent 26 && \
adb shell am start -n uk.co.bbc.iplayer/.BBCIPlayerActivity
sleep 0.5 && \
adb disconnect || exit 0
This one will put it into standby.
#!/bin/bash
sleep 0.5
sleep 0.5 && \
Here are some other commands:
UP = adb shell input keyevent 19
DOWN = adb shell input keyevent 20
LEFT = adb shell input keyevent 21
RIGHT = adb shell input keyevent 22
ENTER = adb shell input keyevent 66
BACK = adb shell input keyevent 4
HOME = adb shell input keyevent 3
MENU = adb shell input keyevent 1
MEDIA PLAY/PAUSE = adb shell input keyevent 85
MEDIA PREVIOUS = adb shell input keyevent 88
MEDIA NEXT = adb shell input keyevent 87
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Loky31
Re: Fire TV Status
Post by Loky31 »
OMFG I din't saw your answer!!!!
Thank you so much! it just works like charm!!!
I was trying to use an addon since quite some time with no success ( :https://github.com/happyleavesaoc/python-firetv), you really got me where I needed :)
