Dashticz won't show temperature value
Erwin92
Post by Erwin92 »
Dear guys,
This evening a set up dashticz to show the information from my Domoticz setup.
But I didn't succeed to show my temperature value.
I made a block and point it to a column with the IDX of my temperature sensor
Schermafbeelding 2018-05-02 om 21.16.49.png (36.37 KiB) Viewed 2484 times
Schermafbeelding 2018-05-02 om 21.16.26.png (106.74 KiB) Viewed 2484 times
But It won't show the information at dashticz.
Could anyone help me, probably I made a very stupid mistake... :oops:
robgeerts
Domoticz version: 3.7067
Re: Dashticz won't show temperature value
Post by robgeerts »
Could you send me the device output of this device from:
http://YOUR_IP/json.htm?type=devices&plan=0&filter=all&used=true&order=Name
Erwin92
Post by Erwin92 »
Hi Rob,
Thank you for the answer.
I just checked the output, it's really strangs because there isn't any IDX 16 :o
I've connected a RFXCOM receiver at my Domoticz setup and it's receiving some 433 mhz temperature sensors, it shout be possible to connect those to dashticz, isn't it?
   "ActTime" : 1525441151,
   "AstrTwilightEnd" : "23:39",
   "AstrTwilightStart" : "03:32",
   "CivTwilightEnd" : "21:44",
   "CivTwilightStart" : "05:27",
   "DayLength" : "15:00",
   "NautTwilightEnd" : "22:35",
   "NautTwilightStart" : "04:36",
   "ServerTime" : "2018-05-04 15:39:11",
   "SunAtSouth" : "13:05",
   "Sunrise" : "06:05",
   "Sunset" : "21:06",
   "result" :
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "LastUpdate" : "2017-12-29 17:06:24",
         "Name" : "test",
         "PlanID" : "",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "Status" : "On",
         "Type" : "Group",
         "TypeImg" : "group",
         "UsedByCamera" : false,
         "XOffset" : 0,
         "YOffset" : 0,
         "idx" : "1"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "Counter" : "1447.915",
         "CounterDeliv" : "0.092",
         "CounterDelivToday" : "0 kWh",
         "CounterToday" : "8.594 kWh",
         "CustomImage" : 0,
         "Data" : "720040;727875;92;0;410;0",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 5,
         "HardwareName" : "P1",
         "HardwareType" : "P1 Smart Meter USB",
         "HardwareTypeVal" : 4,
         "HaveTimeout" : false,
         "ID" : "1",
         "LastUpdate" : "2018-05-04 15:39:11",
         "Name" : "Energie",
         "Notifications" : "true",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Energy",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "P1 Smart Meter",
         "TypeImg" : "counter",
         "Unit" : 1,
         "Usage" : "410 Watt",
         "UsageDeliv" : "0 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "14"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "RFXcom",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : false,
         "HaveGroupCmd" : false,
         "ID" : "80",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2018-05-04 05:00:01",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 0,
         "Name" : "X",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Impuls",
         "SwitchType" : "On/Off",
         "Timers" : "true",
         "Type" : "Lighting 1",
         "TypeImg" : "lightbulb",
         "Unit" : 13,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "19"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "ID" : "80",
         "Image" : "Light",
         "LastUpdate" : "2017-11-17 16:31:52",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 0,
         "Name" : "keuken - klein",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 11,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "20"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "ID" : "80",
         "Image" : "Light",
         "LastUpdate" : "2018-05-04 05:02:01",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 0,
         "Name" : "X",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 10,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "21"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CameraIdx" : "2",
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "18B3482",
         "Image" : "Light",
         "LastUpdate" : "2018-05-04 14:21:42",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Deurbel",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 7,
         "Status" : "",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "Doorbell",
         "SwitchTypeVal" : 1,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "doorbell",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : true,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "22"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0.0 C",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 7,
         "HardwareName" : "D18b20",
         "HardwareType" : "1-Wire (System)",
         "HardwareTypeVal" : 12,
         "ID" : "1EA8",
         "LastUpdate" : "2018-05-04 15:35:20",
         "Name" : "Binnen temperatuur domoticz server",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "LaCrosse TX3",
         "Temp" : 0.0,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 168,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "100"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "25.62%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "HardwareName" : "Domoticz",
         "HardwareType" : "Motherboard sensors",
         "HardwareTypeVal" : 23,
         "ID" : "0000044D",
         "Image" : "Computer",
         "LastUpdate" : "2018-05-04 15:38:42",
         "Name" : "CPU | domoticz",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Percentage",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "hardware",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "105"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "42.8 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 8,
         "ID" : "0001",
         "Name" : "Domoticz | Temperatuur",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Temp" : 42.799999999999997,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "106"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "14.72%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0000044C",
         "LastUpdate" : "2018-05-04 15:38:52",
         "Name" : "Memory | Domoticz",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "107"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "51.71%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0000044E",
         "LastUpdate" : "2018-05-04 15:36:21",
         "Name" : "BOOT | domoticz",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "108"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "15.77%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 8,
         "ID" : "0000044F",
         "Name" : "HDD | Domoticz",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "109"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 9,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "HardwareName" : "Synology NAS",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "ID" : "000140BE",
         "Image" : "Generic",
         "LastUpdate" : "2018-04-23 15:55:01",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "Timers" : "false",
         "Type" : "Light/Switch",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "110"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "28.0 C",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "140BF",
         "LastUpdate" : "2018-05-04 15:35:01",
         "Name" : "Disk 1 | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Temp" : 28.0,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "111"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "28.0 C",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "140C0",
         "Name" : "Disk 2 | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Temp" : 28.0,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "112"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "3%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "00082113",
         "LastUpdate" : "2018-05-04 15:35:02",
         "Name" : "RAM | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "113"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "00082114",
         "Name" : "CPU | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "114"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Barometer" : 1023,
         "CustomImage" : 0,
         "Data" : "19.4 C, 43 %, 1023 hPa",
         "Description" : "",
         "DewPoint" : "6.50",
         "Favorite" : 0,
         "Forecast" : 1,
         "ForecastStr" : "Sunny",
         "HardwareID" : 10,
         "HardwareName" : "Weather undergrond ",
         "HardwareType" : "Weather Underground",
         "HardwareTypeVal" : 14,
         "Humidity" : 43,
         "HumidityStatus" : "Comfortable",
         "ID" : "0001",
         "LastUpdate" : "2018-05-04 15:38:28",
         "Name" : "Temp / Luchtdruk (online)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "THB1 - BTHR918, BTHGN129",
         "Temp" : 19.399999999999999,
         "Timers" : "false",
         "Type" : "Temp + Humidity + Baro",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "forecast_url" : "X",
         "idx" : "138"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Chill" : 19.399999999999999,
         "CustomImage" : 0,
         "Data" : "41.00;NE;13;40;19.4;19.4",
         "Description" : "",
         "Direction" : 41.0,
         "DirectionStr" : "NE",
         "Favorite" : 0,
         "Gust" : "14.4",
         "HardwareID" : 10,
         "ID" : "0001",
         "Name" : "Gevoel (online)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Speed" : "4.7",
         "SubType" : "TFA",
         "Timers" : "false",
         "Type" : "Wind",
         "TypeImg" : "wind",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "139"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "2.9 UVI",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 10,
         "ID" : "0001",
         "Name" : "Uv (online)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "UVN128,UV138",
         "Timers" : "false",
         "Type" : "UV",
         "TypeImg" : "uv",
         "UVI" : "2.9",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "140"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0;0.0",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 10,
         "ID" : "0001",
         "Name" : "Weer (online)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Rain" : "0",
         "RainRate" : "0",
         "SubType" : "WWW",
         "Timers" : "false",
         "Type" : "Rain",
         "TypeImg" : "rain",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "141"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "10.0 km",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 10,
         "ID" : "0",
         "Name" : "Zichtbaar (online)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Visibility",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "visibility",
         "Unit" : 1,
         "Used" : 1,
         "Visibility" : 10.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "142"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "708.0 Watt/m2",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 10,
         "ID" : "0",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Radiation" : 708.0,
         "SubType" : "Solar Radiation",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "radiation",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "143"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "000140E7",
         "Image" : "Light",
         "LastUpdate" : "2017-12-04 16:53:06",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "TEST",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "151"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 6,
         "ID" : "028EC02",
         "Image" : "Light",
         "LastUpdate" : "2018-01-11 15:43:54",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "test afstandbediening",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 6,
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 4,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "153"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 12,
         "HardwareName" : "SONOFF",
         "ID" : "000140EB",
         "Image" : "Light",
         "LastUpdate" : "2018-05-04 07:37:01",
         "Level" : 100,
         "LevelInt" : 100,
         "Name" : "Kerstverlichting achter",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "155"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Counter" : "936 ",
         "CounterToday" : "1 ",
         "CustomImage" : 0,
         "Data" : "936 ",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "14118",
         "Name" : "Vrije ruimte | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "RFXMeter counter",
         "SwitchTypeVal" : 3,
         "Timers" : "false",
         "Type" : "RFXMeter",
         "Unit" : 1,
         "Used" : 1,
         "ValueQuantity" : "B",
         "ValueUnits" : "",
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "200"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "65%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 9,
         "ID" : "00082198",
         "Name" : "Ruimte bezet % | NAS",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "198"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "11.753 ms",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 13,
         "HardwareName" : "Internet",
         "ID" : "00082169",
         "Image" : "Custom",
         "LastUpdate" : "2018-05-04 15:00:33",
         "Name" : "Ping",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SensorType" : 1,
         "SensorUnit" : "ms",
         "SubType" : "Custom Sensor",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "Custom",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "169"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "40.59 mb/s",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 13,
         "ID" : "00082170",
         "Image" : "Custom",
         "Name" : "Upload",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SensorType" : 1,
         "SensorUnit" : "mb/s",
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "170"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "68.59 mb/s",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 13,
         "ID" : "00082171",
         "Image" : "Custom",
         "Name" : "Download",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SensorType" : 1,
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "171"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "227 V",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 5,
         "ID" : "00000001",
         "Name" : "Volt L1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Voltage",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 227.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "204"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "228 V",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 5,
         "ID" : "00000002",
         "Name" : "Volt L2",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 228.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "205"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "228 V",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 5,
         "ID" : "00000003",
         "Name" : "Vol L3",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 228.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "206"
   "status" : "OK",
   "title" : "Devices"
Edit: Also the information of weather underground (IDX 138, 139, 140) isn't showing.
Erwin92
Post by Erwin92 »
I tried to get the information of Idx 16, with the url 192.168.0.40:8080/json.htm?type=devices&rid=16
That will give a “normall” output:
"ActTime" : 1525604220,
"AstrTwilightEnd" : "23:46",
"AstrTwilightStart" : "03:25",
"CivTwilightEnd" : "21:48",
"CivTwilightStart" : "05:23",
"DayLength" : "15:07",
"NautTwilightEnd" : "22:39",
"NautTwilightStart" : "04:31",
"ServerTime" : "2018-05-06 12:57:00",
"Sunrise" : "06:02",
"Sunset" : "21:09",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 0,
"Data" : "27.2 C, 35 %",
"Description" : "",
"DewPoint" : "10.41",
"Favorite" : 1,
"HardwareID" : 6,
"Humidity" : 35,
"HumidityStatus" : "Dry",
"ID" : "1603",
"LastUpdate" : "2018-05-06 12:56:57",
"Name" : "Buiten",
"PlanID" : "1",
"PlanIDs" : [ 1 ],
"SignalLevel" : 5,
"SubType" : "Alecto WS1700",
"Temp" : 27.199999999999999,
"Timers" : "false",
"Type" : "Temp + Humidity",
"Unit" : 3,
"Used" : 1,
"XOffset" : "21",
"YOffset" : "150",
"idx" : "16"
"status" : "OK",
"title" : "Devices"
robgeerts
Post by robgeerts »
I tested your output,,, this is wat I see:
Erwin92
Post by Erwin92 »
With the last posted information?
Is it normal that with the first url domoticz doesn’t show any idx devices? Which URL does Dashticz use?
robgeerts
Post by robgeerts »
Strange... you should see it when requesting: http://192.168.0.40:8080/json.htm?type=devices
Erwin92
Post by Erwin92 »
I just installed domoticz also at my NAS. Connected Dashticz and the Domoticz devices, and.. It works!
I guess something is wrong with my other domoticz installation, when I installed this domoticz setup I restored a back-up. Probably this will changed the IDX numbers. Is this a known problem?
