problem with timedifference / lastupdate not switching switch
sion
Post by sion »
Hi All.
Im have been using domoticz a long time, but new to Lua.
I am trying to get this script to turn off my lights, when there has been no movement on a sensor for a specified amount of time.
the utility lights work fine every time.
But the landing lights dont work. it doesnt even print ('Checking landing lights') in the log.
has anyone got any ideas as to why this isnt working?
is there a limit to the number of things you can use the timedifference function for in a script?
im on Version: 3.8153
Thanks,
Sion.
-- script_time_Lights_out.lua
function timedifference (s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
 if  (otherdevices ['HOME_SECURED'] == 'Off') then
if (otherdevices ['Util_spot_1'] == 'On')  then
 print('evaluating utility room')
 if (otherdevices['utility_sensor'] == 'Off') and (timedifference(otherdevices_lastupdate['utility_sensor']) > 600)  then
         commandArray['Utility_Dummy']='Off'
         print('turning off utility lights')
if (otherdevices['landing_light'] == 'On' ) then
    if (timedifference(otherdevices_lastupdate['landing_pir']) > 900 ) then
        print ('turning off landing light')
        commandArray['landing_light']='Off'
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
jvdz
Domoticz version: 4.107
Re: problem with timedifference / lastupdate not switching switch
Post by jvdz »
It should work fine.
What is the exact name for the device and are you sure it is unique?
Jos
sion
Post by sion »
Hi, thanks for the reply.
I have double checked the exact names etc.
I have now tried making a dummy switch, and using this instead of landing_light seems to work as expected.
Setting it back from landing_dummy to landig_light and it no longer works again.
For now I have just added a conman in the off action of the dummy switch to switch the light off.
Strange how it just won’t work with that one switch though.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
