simple Heater control
honselbonsel
Post by honselbonsel »
Hi Community,
as i am now trust in Domoticz as a perfect System for Home Automation :-)
There is a new Project which i want ti implement in two steps.
The Heating Control of my inWall Heater (like floorheating just vertical)
The initial installation was an wall thermostat (vry simple) you just set the temperature over a wheel and then the valve of the corresponding heat circuit open/closes.
In first step i just want to connect the wall thermostat and also the valves to domoticz over maybe raspberry and an input/output borad.
My Question is just if anybody knows how is this board called? e.g.: i want an analog input signal to be connected from the thermostat and then an relay output for the valves 230v.
Thank You for ideas :-)
br
Jens
renerene
Re: simple Heater control
Post by renerene »
