New Temp/Lighting Sensor from Sensative -_-
sensativeAB
Post by sensativeAB »
Strips Comfort ya'll!
Our newest addition to the Strips family line of products is here and available for Europe! Strips Comfort - the ultra-thin temperature and ambient light monitoring sensor which measures temperature and ambient light (LUX) in any room you place it.
Connected to other smart home devices and apps, Strips Comfort can automatically warn you if the temperature goes above or below what you desire. For example connected to a smart thermostat, the thermostat can automatically be lowered or raised to match the detected temperature change. The insights Strips Comfort provides helps you to manage the energy you need to heat/cool or light a room. ? Its ultra-thin design means Strips Comfort can be discretely mounted in any room you want to place it. And you won’t need to worry about charging or changing batteries for up to 10 years, thanks to its uniquely designed battery
Strips Comfort Features:
Temperature Range : -20 to +60 degree C Temperature Accuracy : +/-0.5 degree C Resolution : 0.1 degree C
Light sensor range: 1-64000 LUX
Strips Comfort offers 2 unique/custom report features
– Program alarms to alert you when Temp reaches above or below a defined value
–Programmable Light report levels to notify you when the light reaches above or below a defined value
https://www.stripsbysensative.com/comfort/
