[RELEASE] Paradox alarm PRT3 serial interface plugin
Posted: Sunday 22 April 2018 11:37
New comer in home automation and Domoticz, I had planned to install an interoperable alarm system (Paradox EVO with serial interface) and get it to work in an open home automation system (Domoticz). Here it is :
https://github.com/Masurov/Domoticz-ParadoxPrt3-Plugin
To sum it up, what you'll get from the plugin :
- an open/closed switch for each alarm zone
- two switches for each alarm area
. a selector for area arming state (selector is french labeled)
. an ON/OFF for the in alarm state
You can change the arming state with the selector
To keep it simple, it does not try to discover the zones/areas from the interface. Though it would have been possible, you have to declare thoses in the plugin configuration.
Hope it will be useful to others
