Help appreciated: LUA script enhancement
antipiot
Domoticz version: Stable
Post by antipiot »
Hello everybody!
I may need assistance:
I took the lua script for the onkyo plugin and tried to modify it to fit my needs to use my pionner AMP: Same instrutions: working as it should:
https://www.domoticz.com/wiki/Onkyo3
Cans somebody knowing LUA read this and correct it if it's bad? :-)
I wanted to know if i should name the script with the name of the virtual device triggering it ( "Source" in my case) i've read somewhere that some script can be triggered by the only device with the same as their name. Is this true?
Thanks for your help!
-- Title: script_device_Onkyo
-- Date: 10-07-2015
-- function to get information from receiver
function onkyo_status(command)
local result = {}
local output = io.popen ('onkyo '..command)
for line in output:lines() do
table.insert(result, line)
output:close()
return result
-- function to change settings receiver
function onkyo_change(command)
os.execute('/usr/local/bin/onkyo '..command)
-- turn the receiver on/off with dummy switch 'Source'
if devicechanged['Source']=="PC" then
onkyo_change('input-selector=dvd')
if devicechanged['Source']=="Recalbox" then
onkyo_change('input-selector=cbl')
if devicechanged['Source']=="Switch" then
onkyo_change('SLI11')
if devicechanged['Source']=="Runeaudio" then
onkyo_change('input-selector=cd')
if devicechanged['Source']=="Off" then
onkyo_change('system-power:standby')
