Err_ssl_protocol_error
Posted: Saturday 21 April 2018 18:23
by domogijs
I tried to access domoticz via https using the 443 port.
So https://ip-adres:443
But I receive an error: ' deze site kan geen beveiligde verbinding leveren'
' **.**.**.**. Heeft een ongeldige reactie verzonden'
I searched the forum and wiki, but in can not find the answer.
Somebody any clue what to try.
Greets Gijs
Re: Err_ssl_protocol_error
Posted: Saturday 21 April 2018 18:58
by jvdz
What do you have in the startup config for domoticz?
The config file for domoticz on Raspberry is: /etc/init.d/domoticz.sh
Look for the initial lines containing DAEMON_ARGS=
Jos
Posted: Wednesday 25 April 2018 20:37
by domogijs
Sorry took some time to find out what to do (noob alert). I did 'cat domoticz.sh'
I see the 443 port. See attachment. What am I doing wrong?
Greets Gijs
Posted: Saturday 28 April 2018 19:28
by domogijs
I think I located the problem; I use a pi hole. The ssl seems to be blocked. Somebody experience with pi hole ivm domoticz 443 port?
Greets Gijs
Posted: Wednesday 01 May 2019 12:19
by geraldmuller
The error message ERR_SSL_PROTOCOL_ERROR error indicates that the browser is not able to initiate the secured communication at the moment. It's almost impossible to pin it down to a single cause, it could be almost anything. There is no definite guide for managing this error. However, there are few changes or settings which help you to get rid you of this error.
Configure Correct Date and Time
Clear Browsing Data
Clear Your SSL State
Disable QUIC Protocol of Chrome
Disable your Internet Browser Extensions
Adjust Your Internet Security and Privacy Level
Remove your system's hosts file
Check Your Antivirus Settings
Check Your Firewall
