fibaro wall plug receive work, send doesn't
elgringo
Domoticz version: Left
Post by elgringo »
So I got a fibaro wall plug, is only has link with another wall plug which can reach the z-wave stick:
z wave
z wave
The second wall plug data is recedived by domoticz. But when I want to toggle the wall plug I get a timeout:
Domoticz reports a timeout.
I tried healing the network but this didn't work. What could I do to solve this?
jake
Re: fibaro wall plug receive work, send doesn't
Post by jake »
Most times you get the devices to life by manually operating them once or twice.
elgringo
Post by elgringo »
Tried this, but also a total reset of controller and wallplugs. Put them into the same room (5cm apart) and re-added them. The first one always works without problems. The second on does not.
It look like the controller only can connect to 1 device, it never connected directly to both. So the topology always looks as above.
Pushing the button on the plug doesn't make any difference.
tontze
Domoticz version: Beta Ch
Post by tontze »
and including order, allways first one works ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
elgringo
Post by elgringo »
The first (when 1 conencted) does always work, when the second is added the second is more instable than the first, however the first also gets timeouts. So I don't think the problem is in the wallplug since they act the same depending on the including order. Both are added a secure node.
Are there any open z wave settings which I might check? Or could there be a configuring setting wrong?
elgringo
Post by elgringo »
Swapped the Z-wave stick. Problem is a bit more related to one wallplug.
The 'bad' plug works normally but after switching it on/off via domotica I get a timeout:
2018-04-20 19:41:44.149 OpenZWave: Received timeout notification from HomeID: 3588394851, NodeID: 3 (0x03)
The 'good' plug is places upstairs and works normally (node 4). So the controller can communicate with the bad plug, node 3, and node 4 communicates with node 3 only (according the topology)
Node 4 does not get any timeouts.
Why do I get timeouts while the wallplug doe respond? Complete log when turning it on and off:
2018-04-22 08:37:18.998 User: pi initiated a switch command (107/Media Power/On)
2018-04-22 08:37:18.999 OpenZWave: Domoticz has send a Switch command! NodeID: 3 (0x03)
2018-04-22 08:37:19.013 (Zwave) Light/Switch (Media Power)
2018-04-22 08:37:19.863 (Zwave) Usage (Media Verbruik)
2018-04-22 08:37:19.864 (Zwave) General/kWh (kWh Meter)
2018-04-22 08:37:21.869 (Zwave) Usage (Media Verbruik)
2018-04-22 08:37:21.871 (Zwave) General/kWh (kWh Meter)
2018-04-22 08:37:25.869 (Zwave) Usage (Media Verbruik)
2018-04-22 08:37:25.871 (Zwave) General/kWh (kWh Meter)
2018-04-22 08:37:28.490 User: pi initiated a switch command (107/Media Power/Off)
2018-04-22 08:37:28.491 OpenZWave: Domoticz has send a Switch command! NodeID: 3 (0x03)
2018-04-22 08:37:28.492 (Zwave) Usage (Unknown)
2018-04-22 08:37:28.493 (Zwave) General/kWh (kWh Meter)
2018-04-22 08:37:28.506 (Zwave) Light/Switch (Media Power)
2018-04-22 08:37:29.068 OpenZWave: Received timeout notification from HomeID: 3588394851, NodeID: 3 (0x03)
2018-04-22 08:37:29.968 (Zwave) Usage (Media Verbruik)
2018-04-22 08:37:29.970 (Zwave) General/kWh (kWh Meter)
WHen switching the wallplug rapidly after each other (within 5 seconds) the timeout reproduces and the wallplug is toggled a bit later.
commentator
Post by commentator »
same problem here
