Xiaomi Gateway FM
Posted: Friday 06 April 2018 17:42
by hekm77
Xiaomi Gateway FM in Domoticz. Playing your channels from MiHome app favorites, obtaining (updating) the status.
  • Install php-miio
    sudo apt update
    sudo apt upgrade
    sudo apt install php7.0
    git clone https://github.com/skysilver-lab/php-miio.git php-miio
  • Get the gateway token and IP:
    cd /home/pi/php-miio/
    php miio-cli.php --discover all
    Or from miio2.db in MiHome (up to 5.0.31)
    Or in MiHome, the tab is located next to developer mode activation.
  • Create two dummy switches miGateway FM and miGateway FM - Source - type: Selector Switch with levels.
  • Create a dzVents script. Change php-miio path, gateway token and IP.
    		--timer = {'every minute'},
    		devices = {'miGateway FM', 'miGateway FM - Source'}
    	logging = {
            level = domoticz.LOG_ERROR
    	execute = function(dz, item)
    	     local Path   = "/home/pi/php-miio/"                  -- php-miio path
    	     local IP     = '192.168.1.50'                        -- Xiaomi Gateway IP
    	     local Token  = 'x1x1x1x1x1x1x1x1x1x1x1x1x1x1x1x1'    -- Xiaomi Gateway Token
             local FM     = dz.devices('miGateway FM')
             local Source = dz.devices('miGateway FM - Source')
           --  Channel ID, Channel Name
             ch1ID, ch1Name = '527782024', 'Европа Плюс'
             ch2ID, ch2Name = '527782027', 'Top 100 Rap'
             ch3ID, ch3Name = '527782029', 'Energy FM'
             ch4ID, ch4Name = '527782034', 'Sound Park Deep'
             ch5ID, ch5Name = '527782069', 'Аплюс Relax BY'
             chID = {}
            chID[#chID+1] = {ch1ID, ch1Name}
            chID[#chID+1] = {ch2ID, ch2Name}
            chID[#chID+1] = {ch3ID, ch3Name}
            chID[#chID+1] = {ch4ID, ch4Name}
            chID[#chID+1] = {ch5ID, ch5Name}
     function SendCommand()
        cmd = "cd "..Path.." && php miio-cli.php --ip "..IP.." --token "..Token.." --sendcmd '{\"id\":1,\"method\":\""..method.."\",\"params\":"..param.."}'"
            if (item.isDevice) then
                   if (item.name == 'miGateway FM') then
                          if (item.levelName == 'Get Channel ID') then
                              method = "get_prop_fm"
                              param  = "[]"
                              SendCommand()
                              local h = io.popen(cmd)
    	                      local r = h:read("*a")
    	                      h:close()
                              _, _, num1, num2, num3, num4, channel = string.find(r, "(%d+)[^%d]+(%d+)[^%d]+(%d+)[^%d]+(%d+)[^%d]+(%d+)[^%d]")
                              print('Channel ID = '..channel)
                              item.switchOff().afterSec(1).silent()
                              method = "play_fm"
                                 if (item.levelName == 'On') then
                                     param =  "[\"on\"]"
                                 elseif
                                    (item.levelName == 'Off') then
                                     param =  "[\"off\"]"
                                     Source.switchOff().checkFirst().silent()
                              SendCommand()
                              dz.utils.osExecute('('..cmd..' > /dev/null)&')
                  if (item.name == 'miGateway FM - Source') then
                         if (item.state == 'Off') then
                             method = "play_fm"
                             param =  "[\"off\"]"
                             dz.devices('miGateway FM').switchOff().silent()
                            for i in pairs(chID) do
                               if (item.levelName == chID[i][2]) then
                                   method = "play_specify_fm"
                                   param = "["..chID[i][1].."]"
                                      if (FM.levelName ~= 'On') then
                                          FM.switchSelector(30).silent()
                      SendCommand()
            if (item.isTimer) then
                param  = "[]"
                SendCommand()
    	        h:close()
                   if (string.find(r, '"pause"')) then
                       FM.switchOff().checkFirst().silent()
                   if (string.find(r, '"run"')) then
                           if (channel == ch1ID and Source.levelName ~= ch1Name) then Source.switchSelector(10).silent()
                               elseif (channel == ch2ID and Source.levelName ~= ch2Name) then Source.switchSelector(20).silent()
                               elseif (channel == ch3ID and Source.levelName ~= ch3Name) then Source.switchSelector(30).silent()
                               elseif (channel == ch4ID and Source.levelName ~= ch4Name) then Source.switchSelector(40).silent()
                               elseif (channel == ch5ID and Source.levelName ~= ch5Name) then Source.switchSelector(50).silent()
                               elseif (channel ~= ch1ID)
                                  and (channel ~= ch2ID)
                                  and (channel ~= ch3ID)
                                  and (channel ~= ch4ID)
                                  and (channel ~= ch5ID) then
                                          if (Source.levelName ~= 'Unknown') then
                                              Source.switchSelector(60).silent()
  • Play a favorite channel in the MiHome app. In the Domoticz GUI click on the Get Channel ID on the miGateway FM switch. The ID of the channel will be shown in the log.
    2018-04-04 12:06:07.502 User: Admin initiated a switch command (86/miGateway FM/Set Level)
    2018-04-04 12:06:07.511 (Dummy) Light/Switch (miGateway FM)
    2018-04-04 12:06:08.135 dzVents: Channel ID = 527782027
  • Copy, paste it and the channel name into the script. Make for all the necessary channels. In the example 5 channels.
  • The channel ID can also be obtained by running in the terminal:
    cd /home/pi/php-miio/ && php miio-cli.php --ip 192.168.1.50 --token xzxzzxzxzzzzzzzx --sendcmd '{"id":1,"method":"get_prop_fm","params":[]}'
    "current_program":527782027
  • If you do not start a channel from MiHome, will be received the channel ID that was last played and now paused.
  • Edit the switch miGateway FM - Source. Change the levels names to your own. The Unknown level is required!
  • Uncomment the line 3 in the script (timer = {'every minute'},). To retrieve (update) playback information every minute.
  • Listen your favorite radio stations from Domoticz
