Save detailed data over 24 hours
Posted: Wednesday 04 April 2018 23:11
by albercola
Hi everyone,
I have a Raspberry 3 that I use to record different temperature of a boiler of mine.I can't find a detailed/basic guide regarding how to save in a separate database ALL daily data (with 5 min interval) before they are overwritten in the day after. Can somebody help me? thanks in advance
Re: Save detailed data over 24 hours
Posted: Thursday 05 April 2018 1:14
by waaren
cd "domoticzdir"
# open domoticz database
sudo sqlite3 domoticz.db
-- file to receive output
.output t_schema
-- send schema of temperature table to t_schema
.schema temperature
.quit
edit t_schema (to give table different name and add a primary key. This will prevent double entries)
CREATE TABLE [Temperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGE
R DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')));
CREATE INDEX t_id_idx        on Temperature(DeviceRowID);
CREATE INDEX t_id_date_idx   on Temperature(DeviceRowID, Date);
to: (schema of table in historyTemperatures.db)
CREATE TABLE [HTemperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGER DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')),PRIMARY KEY (DeviceRowID, Date));
CREATE INDEX t_id_idx        on HTemperature(DeviceRowID);
CREATE INDEX t_id_date_idx   on HTemperature(DeviceRowID, Date);
create new database with one table
sudo sqlite3 historyTemperatures.db < t_schema
create file updateHistory.sql
attach 'historyTemperatures.db' as ht;
select count(*) as entries from ht.HTemperature;
insert or ignore into ht.HTemperature select * from main.Temperature;
create a cronjob that must execute at least every 24 hours but to be on the safe side, I advise to run it more frequent
#!/bin/bash
cd "domoticzdir"
result=$(sudo sqlite3 domoticz.db < updateHistory.sql)
beforeUpdate=$(echo $result | cut -d ' ' -f1 )
afterUpdate=$(echo $result | cut -d ' ' -f2 )
echo Before updating temperatureHistory the table contained $beforeUpdate records.
echo After  updating temperatureHistory the table contains $afterUpdate records.
Please note that if the domoticz developers decide to change the schema of the Temperature table, you have to change the HTemperature table alike.
Have Fun!
Posted: Thursday 05 April 2018 9:54
by CaesarPL
Why don't you use Influxdb and Grafana?
Posted: Thursday 05 April 2018 16:44
by albercola
thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
Posted: Friday 09 November 2018 13:53
by Wienen
albercola wrote:thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
@albercola; did you find a way to accomplish this? I want the same thing only then for my gas and energy consumption.
Hope you can point me in the right direction Image
