Hi everyone,
I have a Raspberry 3 that I use to record different temperature of a boiler of mine.I can't find a detailed/basic guide regarding how to save in a separate database ALL daily data (with 5 min interval) before they are overwritten in the day after. Can somebody help me? thanks in advance
Save detailed data over 24 hours
- waaren
Re: Save detailed data over 24 hours
cd "domoticzdir"
edit t_schema (to give table different name and add a primary key. This will prevent double entries)
to: (schema of table in historyTemperatures.db)
create new database with one table
create file updateHistory.sql
create a cronjob that must execute at least every 24 hours but to be on the safe side, I advise to run it more frequent
Please note that if the domoticz developers decide to change the schema of the Temperature table, you have to change the HTemperature table alike.
Have Fun!
# open domoticz database
sudo sqlite3 domoticz.db
-- file to receive output
.output t_schema
-- send schema of temperature table to t_schema
.schema temperature
.quit
CREATE TABLE [Temperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGE
R DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')));
CREATE INDEX t_id_idx on Temperature(DeviceRowID);
CREATE INDEX t_id_date_idx on Temperature(DeviceRowID, Date);
CREATE TABLE [HTemperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGER DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')),PRIMARY KEY (DeviceRowID, Date));
CREATE INDEX t_id_idx on HTemperature(DeviceRowID);
CREATE INDEX t_id_date_idx on HTemperature(DeviceRowID, Date);
sudo sqlite3 historyTemperatures.db < t_schema
attach 'historyTemperatures.db' as ht;
select count(*) as entries from ht.HTemperature;
insert or ignore into ht.HTemperature select * from main.Temperature;
#!/bin/bash
cd "domoticzdir"
result=$(sudo sqlite3 domoticz.db < updateHistory.sql)
beforeUpdate=$(echo $result | cut -d ' ' -f1 )
afterUpdate=$(echo $result | cut -d ' ' -f2 )
echo Before updating temperatureHistory the table contained $beforeUpdate records.
echo After updating temperatureHistory the table contains $afterUpdate records.
Have Fun!
CaesarPL
Why don't you use Influxdb and Grafana?
albercola
thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
Wienen
@albercola; did you find a way to accomplish this? I want the same thing only then for my gas and energy consumption.albercola wrote:thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
Hope you can point me in the right direction
