Aliexpress have this : https://www.aliexpress.com/item/Z-wave- ... autifyAB=0
Which looks really same as Zipato one here : https://www.youtube.com/watch?v=SWw6j9PHeu0
Could it be same, has anyone tried these, and tested do they actually sense anything ?
Cheap z-wave smoke detectors
tontze
- Domoticz version: Beta Ch
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
HarR
Mine are called Heiman, and also appear to be the same. They work with Domoticz. Just be ware it adds 2 smoke sensors in your list of devices, but only one is reflecting real smoke detection. Have not yet figured out what makes the other one go on and off sometimes.tontze wrote:Aliexpress have this : https://www.aliexpress.com/item/Z-wave- ... autifyAB=0
Sent from my iPad using Tapatalk
ActionHenk
Re: Cheap z-wave smoke detectors
no more about this? i also have 2 heiman smoke detectors and it seems the device id xxxx00 it the best to use.
tontze
Have you tried, do they alarm without z-wave connection, i asked this about seller in aliexpress, he couldnt say
I believe it will, but just to make sure
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
HarR
Have nog tested this. Can’t imagine though it wouldn’t. These type of battery powered Z-wave devices (the Z-wave part of it, not the actual sensor) are in sleep mode, not keeping a connection most of the time. I am sure it’s built in siren will go of, no matter of the Z-wave connection.tontze wrote:Have you tried, do they alarm without z-wave connection, i asked this about seller in aliexpress, he couldnt say![]()
