Wierd lua error after... no change?
pipari
After doing.... nothing? This shows up:
Mon Apr 14 19:09:00 2014 (PAJ2) Temperature (TempPaj2)
Mon Apr 14 19:09:00 2014 Hardware Monitor: Fetching data (System sensors)
Mon Apr 14 19:09:00 2014 (PAJ) Temperature (TempPaj)
Mon Apr 14 19:09:06 2014 Error: Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
Mon Apr 14 19:09:16 2014 Error: Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
Mon Apr 14 19:09:16 2014 (PAJ2) Lux Meter (ZLightSensor1)
Mon Apr 14 19:09:17 2014 Error: Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
Mon Apr 14 19:09:17 2014 (PAJ2) Lux Meter (ZLightSensor1)
Mon Apr 14 19:09:17 2014 (PAJ2) Temperature + Humidity (TempLivingroom)
Mon Apr 14 19:09:19 2014 (PAJ) Temperature + Humidity (TempBathroom)
For some reason some lua script can't get the value from utilitydevice...
I have a event (made with the blocky gui) thats uses my Lightsensor that is under "utilitydevide". When I deactivate it this error dissapears. BUT I havent changed the event... Worked yeasterday. I have not updated Domoticz either.
Hope someone have an idea!
Best regards,
Cristopher
Best regards,
Cristopher
SweetPants
Re: Wierd lua error after... no change?
You have to supply some more information. What is the calling script line?
Hendrik
I have the same problem, change the device for the humidity, and then a error in the log, and the event don't do it
disable the event, and no errors
change to an other hum sensor, and it works well
CubieTruck with Domoticz
RfxTrx 433Mhz Usb, Rfx Sensor, Z-Wave
Slave Raspberry Pi with Domoticz, Piface, P1 usb
pipari
This is the event Im trying to do. THIS worked before.
Is like Domoticz can't get the value from ZLightSensor1 anymore.. when I press "Show current states" I can see the value..
//Cristopher
//Cristopher
- Untitled-1.jpg (24.53 KiB) Viewed 5716 times
pipari
Tried this instead (did a lua script instead):
if ((otherdevices['ZLightSensor1'] <= '20' or otherdevices['DuskSensor'] == 'On') and otherdevices['LivingRoomWindow'] == 'Off') then
commandArray['Scene:LightsInsideON']='On'
print('LightsInsideON triggered!')
pipari
If I want to write a script that turns on say "LightningDevice1" for 10 minutes if "MotionSensor" is triggered. BUT not turn the lights off if the "MotionSensor" is triggered again within 10 minutes... is it possible?
Best regards
Cristopher
Best regards
Cristopher
cask
- Domoticz version: 2.2563
Same thing here: Error: EventSystem: Lua script error (Blockly), Name: test event 2_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
Am i doing something wrong? (sorry for a dumb question, very new to domoticz)
(this is a test event, trying to get the light on for 1 minute, when it is dark)
- Knipsel.PNG (8.64 KiB) Viewed 5495 times
OssiJr
I experience exactly the same. Is there any solution available already?
hnogueira
Hi:
I have the same issue with a utility device for energy meter. Anyone has any idea how to solve this?
regards,
Helder Nogueira
regards,
Helder Nogueira
OssiJr
Use the beta version of domotics and is solved.
Worked for me like charme.
hnogueira
Hi OssiJr:
Where can I find the beta versions?
regards,
Helder
regards,
Helder
hnogueira
Hi all:
Just upgraded to the last version and still have the problem. Anyone can help?
Error: EventSystem: Lua script error (Blockly), Name: teste switch_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
regards,
Helder Nogueira
regards,
Helder Nogueira
- rolandbreedveld
- Domoticz version: 2021.1
Have the same issue with latest stable and latest beta version. (Version: 3.4834 and Version: 3.5187)
Error: EventSystem: in Pwr gpio: [string "-- sript_update_Pwr gpio.lua..."]:5: attempt to index global 'devicechanged' (a nil value)
I use this to read gpio status and update a power counter (every pulse is 100Wh)
the script works perfect, but sometimes these errors in the log
the complete script:
if(devicechanged['Pi gpio1 IN']) then ------ this is line 5
cur_val=tonumber(otherdevices_svalues['Power test'])
print("gpio:" .. tostring(otherdevices['Pi gpio1 IN']) .. " pwr:" .. tostring(cur_val))
commandArray['UpdateDevice'] = 31 .. "|0|" .. tostring(100 + cur_val)
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
- jvdz
- Domoticz version: 4.107
What about when you change that to:
Jos
if(devicechanged['Pi gpio1 IN'] ~= nil) then
return commandArray- rolandbreedveld
jvdz wrote:What about when you change that to:JosCode: Select all
commandArray = {} if(devicechanged['Pi gpio1 IN'] ~= nil) then cur_val=tonumber(otherdevices_svalues['Power test']) print("gpio:" .. tostring(otherdevices['Pi gpio1 IN']) .. " pwr:" .. tostring(cur_val)) commandArray['UpdateDevice'] = 31 .. "|0|" .. tostring(100 + cur_val) end return commandArray
Thanxzz, for the idea, but it gave exactly the same error
- jvdz
So that means that the devicechanged table is none existent. Is this a script that runs as Time Event?
Jos
Jos
- rolandbreedveld
Jos, it's running as lua script from Domotics events, same as Blockyjvdz wrote:So that means that the devicechanged table is none existent. Is this a script that runs as Time Event?
Jos
- jvdz
Is it a script file or a script in the internal script editor?
In the first case: What is the scriptname?
In the second case: Which option did you set in the box underneath the LUA option?
Jos
Jos
- rolandbreedveld
Options in Domoticz: Name "Pwr gpio" / LUA / All /Active
(Domoticz script editor is used)
even with a nil check outside it, the error stays:
Error: EventSystem: in Pwr gpio: [string "-- sript_update_Pwr gpio.lua..."]:16: attempt to index global 'devicechanged' (a nil value)
if(otherdevices['Pi gpio1 IN'] ~= nil ) then
if(devicechanged['Pi gpio1 IN']) then ------>>>> this is line 16, which gives the nil error !!
- jvdz
Change the All to Device as it will now runs for Timer and Variable events as well which will cause this error.
Jos
Jos
