Page 1 of 2
Daily Energy usage cost
Posted: Wednesday 28 March 2018 22:09
by garethiowc
So i've been able to graph my energy usage using the owl micro but i wondered if theres anyway i can get domoticz to automatically work out how much it's costing me.
i pay 14.89p per unit.
many thanks
- Screen Shot 2018-03-28 at 20.55.14.png (19.13 KiB) Viewed 9016 times
Re: Daily Energy usage cost
Posted: Thursday 29 March 2018 10:22
by McMelloW
AT settings ==> meters/counters fill in the cost/kWh.
On the device click on log and then report
Posted: Thursday 29 March 2018 22:52
by garethiowc
ah awesome thank you
i also have a daily meter charge of 14.09p i don't suppose there's anyway to get that to add to the daily cost?
Posted: Friday 30 March 2018 10:54
by McMelloW
I use an average figure per kWh including tax, meter charge etc. This calculated according to the bills of the past few years.
Feel free to think of something clever and post it.
Posted: Friday 30 March 2018 12:57
by dervogt
good idea, if you got the energy bill of last year, you can probably just add a markup for the fixed costs like meter rent, delivery&transport costs etc to the price per unit
Posted: Friday 30 March 2018 13:01
by McMelloW
dervogt wrote: Friday 30 March 2018 12:57
Even better if you have energy bills from a couple of years.
Posted: Friday 30 March 2018 18:39
by MikeF
Here's a simple python script I use which calculates energy cost based on cumulative energy today, and which allows for fixed and variable cost elements:
- Spoiler: show
#!/usr/bin/env python
# -*- coding: UTF-8 -*-
energy_cost.py
Reads 'CounterToday' from Owl energy meter
Writes calculated cost to text device
This version is called from crontab
import requests
import json
# Domoticz variables - change for your installation
fixed = 0 # fixed cost in pence
unit = 13.94 # unit cost in pence
OwlIdx = '<xxx>'
costIdx = '<xxx>'
DomoBaseURL = 'http://<domoticz url:port>/json.htm?type=devices&rid='
DomoWriteURL = 'http://<domoticz url:port>/json.htm?type=command¶m=udevice&nvalue=0&idx='
# End of Domoticz variables
def domoticzread(idx, var):
url = DomoBaseURL + idx
response = requests.get(url)
jsonData = json.loads(response.text)
result = jsonData['result'][0][var]
return result;
kW = domoticzread(OwlIdx, 'CounterToday')
kWh = kW.split()[0]
cost = round((float(kWh) * unit + fixed) / 100 ,2)
cost = "£" + str(cost)
#print kW, cost
url = DomoWriteURL + costIdx + '&svalue=' + cost
r = requests.get(url)
Change the Domoticz variables section to suit your installation. This assumes that your Owl device maintains a variable 'CounterToday' - check the json output for your device.
I run this once a minute from crontab - I would have liked to use lua (so this would update every time the Owl device updates), but I couldn't work out how to extract 'CounterToday'.
Here is an example of my output:
(of course this can be changed for other currencies)
Posted: Saturday 31 March 2018 17:49
by garethiowc
MikeF you hero
this is exactly what i was thinking of but just didn't have the knowledge to put it together.
so i would copy the code you have supplied and save it to a file called energy_cost.py
Once i have made the changes i would run:
choose nano and add the following line to the bottom of the file:
*/1 * * * * /usr/bin/python2.7 /sbin/energy_cost.py >> /var/log/energy_cost.log 2>&1
sorry where would i find the json for the device?
i can see the following in the logs
2018-03-31 16:46:43.495 RFLink: 20;E5;OWL_CM180;ID=003D;WATT=00f1;KWATT=00026bad;
2018-03-31 16:46:43.497 (RFLink Gateway) General/kWh (Power Monitor)
Posted: Saturday 31 March 2018 19:04
by MikeF
Hi garethiowc,
First of all, make sure you change the lines in 'Domoticz variables' section of the code to your values - you'll need to find the idx of your Owl device, and also set up a text sensor in Domoticz, and get its idx.
Once you've got the Domoticz idx of your Owl device, type the following into your browser (replacing the angle brackets with your values):
http://<Domoticz ip:port>/json.htm?type=devices&rid=<Owl idx>
(e.g.,
http://192.168.0.63:8080/json.htm?type=devices&rid=240)
- this is the json output. If you can see a line like this:
then you should be good to go.
Your crontab steps look OK.
Posted: Saturday 31 March 2018 19:48
by garethiowc
Thanks MikeF
just got the script working
apt-get install python-requests
source ~/.bashrc
Posted: Saturday 31 March 2018 19:52
by garethiowc
is the fixed cost the daily meter rental charge or am i understanding that wrong?
Posted: Saturday 31 March 2018 22:18
by MikeF
garethiowc wrote: Saturday 31 March 2018 19:52
is the fixed cost the daily meter rental charge...
Yes
Posted: Sunday 01 April 2018 22:50
by EdwinK
Trying to get this to work with Toon (Eneco), but only get 0.01 pence costs. Of course I wouldn't mind that
Posted: Sunday 01 April 2018 23:04
by garethiowc
- Screen Shot 2018-04-01 at 22.00.26.png (32.14 KiB) Viewed 8690 times
all working great here
thank you so much MikeF
i had to specify the python3 path to get it to work in cron using the following
*/1 * * * * /usr/bin/python3.5 /sbin/energy_cost.py >> /var/log/energy_cost.log 2>&1
added a log output for errors when the cron job runs
next thing to work out would be a weekly and monthly cost output
Posted: Sunday 01 April 2018 23:39
by MikeF
EdwinK wrote: Sunday 01 April 2018 22:50
Have you checked that you've got a variable 'CounterToday' (or change it to something similar) that's producing values to a similar order of magnitude (e.g., 6.392 kWh)? and that your fixed / variable costs are similar? (Of course, you can input these in cents, and change the script to display in € rather than £.)
Posted: Monday 02 April 2018 0:22
by garethiowc
"CounterToday" : "6.6 kWh",
"CustomImage" : 0,
"Data" : "167.985 kWh",
Does any one know if the data sting will reset monthly or just keeps counting?
- Screen Shot 2018-04-01 at 23.21.11.png (23.38 KiB) Viewed 8666 times
Posted: Monday 02 April 2018 7:20
by clubeddie
garethiowc wrote: Monday 02 April 2018 0:22
"CustomImage" : 0,
Data is Just counting, so not usable for monthly costs.
Posted: Tuesday 03 April 2018 10:37
by MikeF
I guess you could get the script to save the cumulative Data value at the beginning of each month
- if 'day' = '01' and 'time' = '00:00' then write Data to uservariable 'MonthStart'
and then subtract MonthStart from current value of Data every time the script runs...
Haven't tried it though!
Posted: Tuesday 03 April 2018 20:14
by EdwinK
This is what I have within the device:
"ActTime" : 1522779214,
"AstrTwilightEnd" : "22:20",
"AstrTwilightStart" : "05:12",
"CivTwilightEnd" : "20:53",
"CivTwilightStart" : "06:38",
"DayLength" : "13:06",
"NautTwilightEnd" : "21:35",
"NautTwilightStart" : "05:56",
"ServerTime" : "2018-04-03 20:13:34",
"SunAtSouth" : "13:05",
"Sunrise" : "07:12",
"Sunset" : "20:19",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "3532.785",
"CounterDeliv" : "0.000",
"CounterDelivToday" : "0 kWh",
"CounterToday" : "5.709 kWh",
"CustomImage" : 0,
"Data" : "1744933;1787852;0;0;517;0",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 35,
"HardwareName" : "Toon",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "1",
"LastUpdate" : "2018-04-03 20:13:13",
"Name" : "Electra",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Energy",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "517 Watt",
"UsageDeliv" : "0 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "199"
"status" : "OK",
"title" : "Devices"
Posted: Tuesday 03 April 2018 23:39
by MikeF
EdwinK wrote: Tuesday 03 April 2018 20:14
My python script uses CounterToday, so if for instance your unit cost is 14.89 and fixed cost is 14.09 (garethiowc's example), then you should get:
cost = (5.709 * 14.89 + 14.09 ) / 100 = 0.99
Can you check your values and your script again?
