Re: control blinds with percentage switch and by time
Posted: Sunday 25 March 2018 12:21
by kniazio
I join the request.
+1
Posted: Tuesday 27 March 2018 17:39
by DeBaat
Interested too.
I just installed Somfy blinds with RTS motors.
They can be controlled by the Somfy Telis remotes of which I have two different kinds.
One is a Pure which can open en close the blinds; tilting the blinds can be by stopping the movement just in the right moment.
The second one is a Mod/Var with an additional scrolling wheel which can be used to tilt the blinds more accurately.
Furthermore, I managed to mimic the Pure remote behaviour with a Blinds switch in Domoticz.
However, pressing the Stop button on the switch is too much delayed to be of any help in this.
So I think it would also help when I can mimic the Mod/Var remote with another type of switch in Domoticz.
Any suggestions appreciated.
Posted: Sunday 01 April 2018 8:17
by kniazio
My blinds are (Push On Button), so this method probably will not work.
Posted: Thursday 17 May 2018 21:15
by jpham
I had the same idea, controlling a blind with a slider. So i created a LUA script in combination with two BASH scripts. In my setup it works with the standard domoticz interface, but if i use Dashticz it sometimes reacts strange.
I have one major problem: if the slider is set below 10%, OTHERDEVICES returns 'nil'. The same thing happens with the switch type "Blinds Percentage". Is this a bug?
I have copied the sunscreen.lua, suncreen_open.sh and sunscreen_close.sh in one file. I can't add three separate files as attachment??
Sunscreen.txt
(5.65 KiB) Downloaded 221 times
Posted: Monday 28 May 2018 6:17
by miroslavpetrov
I also have this problem. I am controlling mechanised windows with Sonoff Dual relais flashed with ESPURNA firmware. It takes 42 seconds to fully open the windows. In espurna I have set an auto off the relais after 42 seconds(When a relay is set to on it turns off after 42s). I have made bash scripts with mqtt commands for opening and closing. For stopping the windows at certain possition, I have made a push on button in domoticz that I called Stop All.
It is a bit of frustrating so I am looking for a better solution. I want to use percentage values or multi switch with different percentages as someone above showed.
Posted: Thursday 12 July 2018 11:47
by astrapowerrr
hi intresting topic...
gonna read this..
Posted: Thursday 12 July 2018 13:37
by EdddieN
Interested! following...
