control blinds with percentage switch and by time
kniazio
Domoticz version: 3.7243
Re: control blinds with percentage switch and by time
Post by kniazio »
I join the request.
+1
DeBaat
Domoticz version: V3.8153
Post by DeBaat »
Interested too.
I just installed Somfy blinds with RTS motors.
They can be controlled by the Somfy Telis remotes of which I have two different kinds.
One is a Pure which can open en close the blinds; tilting the blinds can be by stopping the movement just in the right moment.
The second one is a Mod/Var with an additional scrolling wheel which can be used to tilt the blinds more accurately.
Furthermore, I managed to mimic the Pure remote behaviour with a Blinds switch in Domoticz.
However, pressing the Stop button on the switch is too much delayed to be of any help in this.
So I think it would also help when I can mimic the Mod/Var remote with another type of switch in Domoticz.
Any suggestions appreciated.
kniazio
Post by kniazio »
My blinds are (Push On Button), so this method probably will not work.
jpham
Post by jpham »
I had the same idea, controlling a blind with a slider. So i created a LUA script in combination with two BASH scripts. In my setup it works with the standard domoticz interface, but if i use Dashticz it sometimes reacts strange.
I have one major problem: if the slider is set below 10%, OTHERDEVICES returns 'nil'. The same thing happens with the switch type "Blinds Percentage". Is this a bug?
I have copied the sunscreen.lua, suncreen_open.sh and sunscreen_close.sh in one file. I can't add three separate files as attachment??
Sunscreen.txt
(5.65 KiB) Downloaded 223 times
miroslavpetrov
Post by miroslavpetrov »
I also have this problem. I am controlling mechanised windows with Sonoff Dual relais flashed with ESPURNA firmware. It takes 42 seconds to fully open the windows. In espurna I have set an auto off the relais after 42 seconds(When a relay is set to on it turns off after 42s). I have made bash scripts with mqtt commands for opening and closing. For stopping the windows at certain possition, I have made a push on button in domoticz that I called Stop All.
It is a bit of frustrating so I am looking for a better solution. I want to use percentage values or multi switch with different percentages as someone above showed.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
astrapowerrr
Post by astrapowerrr »
hi intresting topic...
gonna read this..
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Interested! following...
11101101 - www.machinon.com
