dzvents timer problem  [Solved]
pgas37
Post by pgas37 »
Rapsberry pi V3
Domoticz version 3.8153
Dzvents version 2.20
I need a timer that:
- starts 60 minutes after sunrise
- is activted inly during daytime
- every 5 minutes
I tried : timer = {' 60 minutes after sunrise at daytime every 5 minutes'}, but that doesn't work
I tried to solve the problem by retrieving the minutes after sunrise with: MinAfterSunrise = timeofday['SunriseInMinutes'] and put the output in an if/then statement, but "MinAfterSunrise " always returns with the same number.
Can anyone help me with this one?
thanks a lot
regards
Paul
landaisbenj
Domoticz version: stable
Re: dzvents timer problem
Post by landaisbenj »
If you do this 60 after sunrise it's not daytim...
Try to create a planified dummy.
And do a script who start like this:
If otherdevice['ThisDummy']=='On' and (os.date('%M') % 5)==0 then
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
landaisbenj wrote: Monday 19 March 2018 12:28 If you do this 60 after sunrise it's not daytim...
This code will not work in dzVents 2.4 (not sure it will in 2.2)
pgas37 wrote: Monday 19 March 2018 11:56 I need a timer that:
- every 5 minutes
Try
	on = { timer = { 'every 5 minutes at daytime' } },
	execute = function(domoticz, _)
        if (domoticz.time.secondsSinceMidnight/60) > (domoticz.time.sunriseInMinutes + 60) then
            print ("I should do something now")
            print ("I should wait a little longer")
pgas37
Post by pgas37 »
both thanks for your answer.
I tested the solution of Waaren (no extra dummySwitch), which can be followed with some simple print commands, and it worked well.
Thanks a lot!
regards
Paul
McMelloW
Domoticz version: V2024.1
Re: dzvents timer problem  [Solved]
Post by McMelloW »
dzVents is far more easier then that. :) :)
I use this for a dzVents script and it works perfect
		timer = { 'every minute between 15 minutes before sunrise and 15 minutes after sunset' }
So you try this for a change
		timer = { 'every 5 minutes between 60 minutes after sunrise and sunset' }
The syntax is about this
		timer = { 'interval between first time and second time' }
Look here for the Timer trigger rules
Thanks to dannybloe
Greetings McMelloW
