in domoticz P1 reading, you can download to xls or csv. Is it possible to get more dayly data out off the Pi table written by the P1.
Now i get only 24 ours in the day reading.
p1 reading download more data
- lsp242
- Domoticz version: 16960
Gadget freak - Domoticz beginner - ios and android user
- waaren
Re: p1 reading download more data
Not directly with a per 5 minute granularity. This granular data is only kept for 24 - 168 hours. (defined in settings)lsp242 wrote: Thursday 15 March 2018 13:15 Hi,
if you want to keep this kind of details you will have to retrieve it daily and store it elsewhere.
I do something similar (get P1, water and weather information from HomeWizard) with a cron job and store it in a separate database.
You can retrieve P1 data (Power and Gas) from the domoticz database with sqlite3
-- 1 row per 5 minutes Power
select * from MultiMeter where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1"));
-- 1 row per 5 minutes Gas
select * from Meter where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1"));
-- 1 row per day Power
select * from MultiMeter_Calendar where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1"));
-- 1 row per day Gas
select * from Meter_Calendar where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1"));
- lsp242
Thnx, can you put me in the direction to find how to install sqlite on pi and were to edit code? I'm just a beginnerwaaren wrote: Thursday 15 March 2018 14:17Not directly with a per 5 minute granularity. This granular data is only kept for 24 hours.lsp242 wrote: Thursday 15 March 2018 13:15 Hi,
You can retrieve P1 data (Power and Gas) from the domoticz database with sqlite3Code: Select all
-- 1 row per 5 minutes Power select * from MultiMeter where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1")); -- 1 row per 5 minutes Gas select * from Meter where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1")); -- 1 row per day Power select * from MultiMeter_Calendar where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1")); -- 1 row per day Gas select * from Meter_Calendar where DeviceRowID in (select ID from DeviceStatus where HardwareID in (select ID from Hardware where Name = "P1"));
- waaren
!! before you are going to play with the database ensure you have a recent backup !!
https://sqlite.org/docs.html
sudo apt install sqlite3
cd domoticzdir
sudo sqlite3 domoticz.db
.header on
.tables
- lsp242
thnx i will look into it.
be sure don't i have toe install php7.0-sqlite on de Pi? I read on google i need that, but when i do "sudo apt-get install php7.0-sqlite3" i've got the error message "E: Kan pakket php7.0-sqlite3 niet vinden" in english "E:can't find package php7.0-sqlite3"
When i only use php-sqlite i've got the same problem.
