script: python import error - UPDATE [solved]
lupo2a
Post by lupo2a »
I installed from scratch a with noobs raspbian environment and domoticz 3.8984
in a dzVents script I have the followig line
suona=os.execute('/usr/bin/python /home/pi/scripts/play_song.py -20 /home/pi/Music/Gabbani_Occidentali.mp3 /home/pi/scripts/log/test.txt 0 >/home/pi/scripts/log/test_err.txt 2>&1 &')
When the script runs In the test_err.txt there is the following error
  File "/home/pi/scripts/play_song.py", line 3, in <module>
    import rxv
ImportError: No module named rxv
If I log in with usr pi and run the same command line it works.
Any help?
UPDATE 20180314
It look like the item is related to the fact that, despite the definition of USERNAME=pi in domoticz.sh, the domoticz process is owned by root
I installed the rxv module as root and it works
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- Neo CoolCam Door Detector and plug
- FIBARO FGWPE Wall Plug
- 6 FIBARO System FGRM222 Roller Shutter Controller 2
- Kodi SamnsungTV Yamaha plugin
- pluginn manager
- Netatmo
