Double dashticz
tontze
- Domoticz version: Beta Ch
Double dashticz
Can dashtcz be run in two different folder in same domoticz ? If i want to run stable and beta separately, or want to run dashticz for kids separately ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- DewGew
- Domoticz version: V4.10618
Re: Double dashticz
Yes you can or you cn use custom_2 for an additinal setup. see wiki https://www.domoticz.com/wiki/Dashticz_ ... Dashboards
aiolos
- Domoticz version: stable
Re: Double dashticz
The solution with custom_2 is a good option if you use the same dashticz version.
If you want to use Stable and Beta, you can make a second checkout of the dashticz repository. If you now have http://domoticz:port/dashticz/ you could also make a new checkout with the name dashticz_beta that can be called with http://domoticz:port/dashticz_beta/ (And with the symlink option given here you can also keep dashticz after an update of domoticz.
