I'm new to this forum and also quite new to Domoticz and I have a question about the daily report. As I understand every night at 0:00 the value from the different counters are written to the database. Now I'm having some problems understanding them. When I look at the following report for the T1 Electricity counter from February I can't see how these values are calculated. For instance the value of 1008,778 for 1 Donderdag is the value of the counter at the beginning of the day. I would make more sense to if this was the value at the end of the day. But I don't see how the value for the column 'Verbruik T1' is determined. When I subtract the values for the counter from 2 consecutive days I get the numbers in the column '(C+1)-C'. Because of this the value for 'Kosten' is also wrong.
To clarify the table: the first 5 columns are from the Domoticz report, the last 2 I've added myself.
Understanding the daily report
Henry
- Domoticz version: 2024.7
- Knipsel.PNG (48.19 KiB) Viewed 641 times
Onyx61
Re: Understanding the daily report
Looks like you have the same problem I do. Don't know how to solve (yet). Do know the cause.
My Domoticz has an interval from 5 minutes. There is the problem.
In your Example:
Wednesday: 1262.926 is the value from the beginning of the day 00.00.01
Last registration that day is at 23.55.00. The value 8,063 is the difference between value from 23.55 and 00.00.
Then the new value 1271.014 is from 00.00.01, so there are missing 5 minutes...
Try to figure out how to set the interval to 1 minute, or perhaps set to the interval reading to 23.59.59 but cannot find how to do that.
In your Example:
