Install Domoticz on OS High Sierra
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
Hello
Somebody has success to install Domoticz on High Sierra?
I followed the tuto for Sierra. i have these following messages :
first message: --> brew link openssl --force
Warning: Refusing to link: openssl
Linking keg-only openssl means you may end up linking against the insecure,
deprecated system OpenSSL while using the headers from Homebrew's openssl.
Instead, pass the full include/library paths to your compiler e.g.:
-I/usr/local/opt/openssl/include -L/usr/local/opt/openssl/lib
Second message : --> brew linkapps python3
Warning: Calling 'brew linkapps' is deprecated!
There is no replacement.
/usr/local/Homebrew/Library/Homebrew/cmd/linkapps.rb:18:in `linkapps'
Linking: /usr/local/opt/python/IDLE.app
Linking: /usr/local/opt/python/Python Launcher.app
Linked 2 apps to /Applications
However, I can compile domoticz but no Webserver launched. Messages are:
2018-03-06 14:06:44.283 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2018-03-06 14:06:44.285 WebServer(HTTP) started on address: :: with port 8080
2018-03-06 14:06:44.291 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: use_certificate_chain_file: No such file or directory
2018-03-06 14:06:44.291 Error: WebServer(SSL) check privileges for opening ports below 1024
Thank you for your help
