Problem with Aeotec ZW075 Smart Switch Gen5+
Varazir
Post by Varazir »
I have problem with my Aeotec ZW075 Smart Switch Gen5+, I keep getting this in the log
2018-02-26 23:52:11.095 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-02-26 23:52:11.096 Always,
2018-02-26 23:52:11.096 Always, Dumping queued log messages
2018-02-26 23:52:11.097 Always,
2018-02-26 23:52:11.097 Always, End of queued log message dump
I have tried to remove and add it again, it worked for few min then it started to drop
I'm running version 3.8968
Varazir
Re: Problem with Aeotec ZW075 Smart Switch Gen5+
Post by Varazir »
I have this problem again.
I also see this in the log
2018-05-12 08:51:07.665 OpenZWave: Received Node Dead notification from HomeID: 3260666225, NodeID: 15 (0x0f)
I'm running 3.9424
Flopp
Post by Flopp »
Hi, is your plug working correctly?
I am having problem to get the Watt/kWh report to be excepted by DZ.
I get this in the log
"OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Unknown, Instance: 1"
