Hi. For many this will be obvious but I Can't find some help for how to interface the kwh pulses as to display the kwh value incl trending. Any help to give me a push in right direction is welcome. I am using a raspberry pi 3 wifi and own a number of arduinos.
Tia
BartSr
[closed] Kwh pulse measuring
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
SweetPants
Re: Kwh pulse measuring
Depends on the meter usedBartSr wrote: Tuesday 27 February 2018 11:30 Hi. For many this will be obvious but I Can't find some help for how to interface the kwh pulses as to display the kwh value incl trending. Any help to give me a push in right direction is welcome. I am using a raspberry pi 3 wifi and own a number of arduinos.
Tia
BartSr
BartSr
It's Brand Eastron type sdm120-a/d/db. I believe with collector output. 1000 pulses = 1 kwh.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
SweetPants
Found this on the forum http://www.domoticz.com/forum/viewtopic.php?t=17411
BartSr
This is "c" version equipped with modbus output whereas mine (not a C-version) is only provided with pulse-output.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
