dzvents and ifttt [Solved]
bdormael
dzvents and ifttt
couldnt find it back in the docs:
via LUA you can do a command array which executes a webhook in ifttt via "triggerifttt"
Does something similar exists fir dvents?
- waaren
Re: dzvents and ifttt
(as adviced by Danny) IFTTT not implemented yet in native dzVents domoticz.notify but can be triggered using domoticz.sendCommand if you defined and activated IFTTT in settings -> notifications
on = { devices = { "domoticz Triggerdevice" } },
eventName = "IFTTT triggername"
value1 = "test1"
value2 = "test2"
value3 = "test3"
domoticz.sendCommand("TriggerIFTTT", eventName .. "#" .. value1 .. "#" .. value2 .. "#" .. value3 )
bdormael
Cool, thxwaaren wrote:IFTTT not implemented yet in native dzVents domoticz.notify but can be triggered using domoticz.sendCommand if you defined and activated IFTTT in settings -> notifications
return { on = { devices = { "domoticz Triggerdevice" } }, execute = function(domoticz, device) eventName = "IFTTT triggername" value1 = "test1" value2 = "test2" value3 = "test3" domoticz.sendCommand("TriggerIFTTT", eventName .. "#" .. value1 .. "#" .. value2 .. "#" .. value3 ) end }
Verzonden vanaf mijn iPad met Tapatalk
- DewGew
- Domoticz version: V4.10618
I do like this:
I added this code to my 'global_data.lua'
Now I can call send ifttt notification from all my dzVents script with:
helpers = {
-- Send IFTTT Notification
iftttNotify = function(domoticz, subject, body)
eventName = 'Domoticz'
prefix = 'Domoticz:'
domoticz.sendCommand("TriggerIFTTT", eventName .. "#" .. prefix .. "#" .. subject .. "#" .. body )
}Code: Select all
domoticz.helpers.iftttNotify(domoticz, 'subject text here', 'body text here')Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
pvklink
- Domoticz version: latest b
To use the notification in IFTTT, what service / applet do i have to install in IFTTT.
Is it possible to let my google home speak with this for example?
Jablotron connection, Ikea
- waaren
triggerIFTTT is a native dzVents command in dzVents >= 2.4.18pvklink wrote: Tuesday 04 June 2019 15:14 To use the notification in IFTTT, what service / applet do i have to install in IFTTT.
It will call an IFTTT maker event (webhook)
pvklink
ok, thats great!
And the other script, what is the purpose of sending a notification to ifttt, which service/applet is reacting on this notification?
- waaren
the triggerIFTTT takes care of the If This partpvklink wrote: Tuesday 04 June 2019 20:44 ok, thats great!
the Then That part can be any IFTTT action service (there are thousands). I use mail, pushover, Hue, SmartLife to name a few.
pvklink
Clear, i also use IFTTT to manage my domoticz devices via my rpi google home...
But to make things work you have to make an applet with a If (service) and a then (service).
In my case i use google home for the IF and often WEBHOOKS for the THEN.
How do i call the THEN service (with the IFTTT domoticz routine, i dont see a ID, the applets have an Applet version ID 100306821. i dont see such an ID for the for THEN services....
I tried..
do you have a working example ?
can i call for example the webhook service with the domoticz call?
url https://x:[email protected]:1880/t
method post
content/type application/json
body {"command": "switchlight", "idx": 1002, "switchcmd": "On"}
I tried..
devices = {
'testifttt'
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
eventName = "Play a Sonos favorite with Google Assistant"
value1 = "Natural"
value2 = "Studeerkamer"
value3 = "this room only"
}url https://x:[email protected]:1880/t
method post
- waaren
The domoticz IFTTT (dzVents triggerIFTTT) does the IF part. The THAT part is on the 'other' site. The name of the maker event is the trigger for IFTTTpvklink wrote: Wednesday 05 June 2019 14:59 How do i call the THEN service (with the IFTTT domoticz routine, i dont see a ID, the applets have an Applet version ID 100306821. i dont see such an ID for the for THEN services....
from the wiki:
triggerIFTTT(makerName [,sValue1, sValue2, sValue3]): Function. 2.4.18 Have Domoticz 'call' an IFTTT maker event. makerName is required, 0-3 sValue's are optional. Supports command options.
pvklink
Re: dzvents and ifttt [Solved]
finally got it working....
made a test_event with webhooks as IF and webhooks as THEN.
called the name of the applet and my light goes on....
Would be great if you can have more IF's and then response and then ACTION. In this way i can trigger my device from google home and by IFTTT domoticz with the same reaction via google home... and do the same action
but for now ok! thanks waaren!
- waaren
Great !
You might want to have a look at thisWould be great if you can have more IF's and then response and then ACTION. In this way i can trigger my device from google home and by IFTTT domoticz with the same reaction via google home... and do the same action
Adding multiple devices to IFTTT
A PHP script is available that makes it easier to have all of your devices on IFTTT while only requiring you to create two IFTTT applets.
You can read more about it and download here: https://github.com/dswinton/domo-ifttt
pvklink
true!
I had that installed in previous/older installations!
i switched from http get commands to post with json bodies, and node-red and mqtt
Dont think i can combine it... domo-ifttt uses devices-names and select id's with it...
I think that is hard to do with node-red and mqtt
