dzVent script device trigger * bug?
Posted: Sunday 25 February 2018 12:49
by snuiter
So I am having two door sensors deur1 and deur2, when I create a script to notify on door open it works fine when triggered by a device. Now I changed script to be triggered by deur* and it is now sending out notifications now and then even when there was no trigger of any of the devices. This is awkward as both deur1 and deur2 have not been triggered since yesterday
Anyone an suggestion what this could be
2018-02-25 12:32:02.905 dzVents: deur script
2018-02-25 12:32:02.906 dzVents: deur open-3
2018-02-25 12:32:02.910 dzVents: deur script
2018-02-25 12:32:02.910 dzVents: deur open-3
It works fine when only using deur1 and deur2 as device triggers but not when I use deur* in the script.
I thought I check my device listings on "deur" and noticed there is also "Voltage - deur1" and "Voltage - deur2" and when there is an update on the voltage the script is triggered. To me this seems to be in error as the trigger is deur* and not *deur*.
Should this be reported as a bug?
This is the script:
- Spoiler: show
devices = {
'deur1','deur2','deur*'
local now = domoticz.time -- current time
print("deur script")
if now.hour <= 7 and now.wday ~= 1 then
print("deur open-1")
if now.hour >= 22 and now.wday ~= 1 then
print("deur open-2")
if now.wday == 1 then
print("deur open-3")
Re: dzVent script device trigger * bug?
Posted: Sunday 25 February 2018 13:07
by emme
well.. deur* already include deur1 and deur2... so you might want to simply specify deur* as on device condition.
then in your script, if you need (but you actually do not in you script) you can use
if device.name == 'deur1' then
elseif device.name == 'deur2' then
to make different action based on the device triggered.
ciao
M
Posted: Sunday 25 February 2018 20:59
by snuiter
Thx M for your response.
But the strange behavior is that if the script only has deur* as device listed it also gets triggered by the two devices that only monitor the voltage of the two door switches e.g.
- Voltage - deur1
- Voltage - deur2
So the script is not only triggered by the two "deur" switches but also through an update of the voltage device.
So these four devices trigger the script due to "deur*" So no door is opened but the script gets triggered by an voltage update from battery of the door switch. For now I will use "deur1" and "deur2" as my triggers and not the simple "deur*"
- Schermafdruk 2018-02-25 20.55.46.png (53.15 KiB) Viewed 1159 times
Posted: Sunday 25 February 2018 21:02
by emme
oh, then it would be
devices = {
'deur1','deur2','*deur*' to trigger also for Voltage - Deur
Posted: Sunday 25 February 2018 21:51
by waaren
snuiter wrote: Sunday 25 February 2018 20:59
- Voltage - deur1
- Voltage - deur2
Kind of interested what the output is of
print("Script triggered by: " .. device.name)
Posted: Sunday 25 February 2018 22:54
by snuiter
The script got triggered by the batteries and that is the problem I don't want that. To me a bit awkward as this is not matching with "deur*"
Script:
- Spoiler: show
- return {
devices = {
'deur*'
2018-02-25 22:48:41.898 dzVents: Script triggered by: Voltage - deur1
2018-02-25 22:48:41.898 dzVents: deur open-3
2018-02-25 22:48:41.902 dzVents: Script triggered by: Voltage - deur2
2018-02-25 22:48:41.902 dzVents: deur open-3
- Schermafdruk 2018-02-25 22.50.25.png (115.48 KiB) Viewed 1145 times
Posted: Sunday 25 February 2018 23:30
by waaren
Looks indeed to be a bug; but best to ask Danny if it is not working as designed.
Logic in domoticz/dzVents/runtime/Eeventhelpers.lua only checks if an "*" is in the scriptTrigger and if so, if the rest of the scriptTrigger string is found in the target device name, without considering if its at the beginning or at the end.
Although fixable it is not as easy as it looks at first sight.
Until it is fixed I propose a rename of your voltage or door contacts.
Posted: Monday 26 February 2018 8:20
by dannybloe
Indeed.. what you can try is in Eventhelpers.lua, function self.findScriptForTarget, replace this line:
scriptTrigger = string.gsub(scriptTrigger, "*", ".*")
with
scriptTrigger = '^' .. string.gsub(scriptTrigger, "*", ".*")
I think that should do the trick.
Posted: Monday 26 February 2018 8:45
by waaren
dannybloe wrote: Monday 26 February 2018 8:20
with
Thanks Danny, this indeed does the trick for a trailing "*" but does not change the behaviour for a leading "*"
Posted: Monday 26 February 2018 9:00
by dannybloe
Which matching goes wrong then?
Posted: Tuesday 27 February 2018 0:27
by waaren
dannybloe wrote: Monday 26 February 2018 9:00
please see my testcode. I also sent you a PM about this.
Wildcard test
defined three devices
triggertest_wildcard
wildcard_triggertest
triggertest_wildcard_triggertest
on = { devices = { "wild*" } },
This reacts as expected (triggers on wildcard_triggertest )
on = { devices = { "*wildcard*" } },
This reacts as expected (triggers on all three devices )
on = { devices = { "*card" } },
This reacts not as expected (triggers on all three devices and I expected to only trigger on ttriggertest_wildcard)
print("RvW Script triggered by: " .. device.name)
