And thank you in advance for your help.
I am rather new to the home automation and IoT realm and am therefore just learning the skills.
I am attempting to gather temperature and humidity information via a DHT22 running on an ESP8266 NodeMCU V2 and would like to display the temperature and humidity data for each sensor in Domoticz.
I have scoured the web and read a massive number of posts on various forums all with the result of becoming extremely confused, which I hope is not a permanent condition.
I would be very appreciative if one of you would kindly offer a step by step process that I may follow to accomplish my goal. You can assume that I will flash each ESP8266 with the ESPEasy software, which I know how to do.
I know this is asking a lot. But once accomplished we would then have a process others could follow to accomplish the same goal without the pain involved with hours of confusing research.
John
ESP8266 NodeMCU - DHT22 - Domoticz
JHMarshall
kimot
- Domoticz version: v3.8153
Re: ESP8266 NodeMCU - DHT22 - Domoticz
http://bryceautomation.com/index.php/20 ... -domoticz/
I think it is steb by step ....
Google is your friend ...
( Sometimes ... )
( Sometimes ... )
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
freijn
- Domoticz version: Stable
To avoid weird issues, You need a resistor as well !
https://www.rototron.info/wp-content/up ... T22_02.jpg
JHMarshall
Thanks so much for your help.
This has cleared up a lot for me.
John
John
