impossible execution code LUA
figaro
Post by figaro »
Hello everyone
I start in the LUA coding, I have a contact to which I try a code it is to display a text in a virtual device, I simply copied the following code:
- Lighting Entry Light.
if (devicechanged ['tank']) then
commandArray [ 'tank'] = 'On'
print ('Ignition')
http: //192.168.X.XX: 8080 / json.htm type = command & param = udevice & idx = 4 & sValue ignition =
what is incredible is when I remove the line "http ........." I have the text "ignition" which displays in the domoticz log and when I place the line "http .. ......... "in the program I have the error:
2018-02-21 19: 53: 02.118 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_on.lua: /home/pi/domoticz/scripts/lua/script_device_on.lua:4: expected near ' / '
and I no longer have "ignition" in the Log
I have no null password, for the virtual sensor I chose as sensor type "TEXT"
if a charitable soul can help me, or if someone has already had this problem because I will crack
Thanks for your help
jvdz
Domoticz version: 4.107
Re: impossible execution code LUA
Post by jvdz »
figaro wrote: Wednesday 21 February 2018 22:19 http: //192.168.X.XX: 8080 / json.htm type = command & param = udevice & idx = 4 & sValue ignition =
Is that first line the actual code? if so then it makes perfect sense you get an error as that is invalid syntax.
Look at UrlOpen in the EventSystem wiki page for the proper syntax. The end of the url also looks wrong by the way:
Something like this should be close:
commandArray['OpenURL']='http://192.168.X.XX:8080/json.htm?type=command&param=udevice&idx=4&sValue=ignition'
The other thing to be careful with is creating an endless loop as your action acts on changes for device 'tank' which you then change yourself as well.
Jos
figaro
Post by figaro »
Hello
I thank you for this answer I will try, I think your explanation will be enough for it to work
Thank you again for your help
