availability of table domoticz (dz)
emme
Domoticz version: latest
Post by emme »
Ciao,
a question....
I have a script in dzVents that cares about heating.
Its configuration is a table with all data in it... included the wanted temperature.
Actually it is a simple float value, but I was willing to have a selector switch (or a virtual setpoint) to setup in a smarter way
My questionis... I define the table at the top of the script before the return { } option...
local roomAdjust  = {}
roomAdjust['Camera']    = {'TEM_Camera',         'SPC_Camera',    23.0, 0.3, 4, 5, 26, 0.5, 0, 'MAG_Camera_Finestra',    15 }
the 3rd position is the wanted temp
Is there a way to get a evice value before the dzvents instructions?
like
roomAdjust['Camera']    = {'TEM_Camera',         'SPC_Camera',    dz.devices('mySetPoint').setPoint, 0.3, 4, 5, 26, 0.5, 0, 'MAG_Camera_Finestra',    15 }
"We always done this way"
dannybloe
Re: availability of table domoticz (dz)
Post by dannybloe »
Nope. There's no domoticz object at that stage. The code before return is executed as soon as the module is loaded. The execute function is called by dzVents at later stage when the events are dispatched to the loaded modules (after it has determined whether the on-triggers matched the event).
emme
Post by emme »
ok.. I will defenetly change the script to reffer to the setpoint device instead of the wanted temp...
thanks a lot for your reply!
ciao
M
