PIR activated - Light on for 1 minute at 50%
htilburgs
Post by htilburgs »
Domoticz v3.8914
Fibaro Motion Sensor FGMS001
What I'm trying to do is to switch the hall light for 1 minute at 50% when PIR is activated between 23:00 and 06:30.
dzVents script:
    on =
        devices =
            {['PIR - Trap'] = {'between 23:00 and 06:30'}},
            'Lamp Gang'
        if
            {(device.name == 'PIR - Trap' and device.state == 'On') and
            (device.name == 'Lamp Gang' and device.state == 'Off')}
        then
            domoticz.devices('Lamp Gang').dimTo(50).forMin(1)
            domoticz.log('Lamp zolder ingeschakeld door PIR Trappenhuis')
Sometimes this works, but most of the time the light stays on. I've seen in the dzVents examples that this may be the case and I'll have to use something like
light.switchOff().checkFirst().afterMin(5)
light.switchOn().checkFirst().forMin(5)
but that this doesn't work in combination with .dimTo()
So for now I'm stuck and I can't get this to work.
Any help would be appreciated....
Hardware:
dannybloe
Re: PIR activated - Light on for 1 minute at 50%
Post by dannybloe »
checkFirst() is nothing more than an encapsulated if-statement so leave out the checkFirst and do the check using an if-statement
if (light.active) then
	light.switchOff().afterMin(5)
	light.switchOn().forMin(5)
And you can better use the dzVents sub-forum.
