Global USer Variables type
emme
Domoticz version: latest
Post by emme »
Ciao
could it be possible to evaluate to implement new kind of user Variables?
In particular a boolean (True, False) and a json/table object type could be really helpful!
I have few script that uses tables as config paramenters, but since they are within the scripts it is quite unconfortable to edit the script to fine tune parameters
I was looking for a different approach and user variables are the best way, but I have to set them up as strings and then convert into the script....
I would be nice to have them already in this way... unfortunately also a JSON viewer/editor/validator should be implemented
ciao
M
"We always done this way"
dannybloe
Re: Global USer Variables type
Post by dannybloe »
I know you use dzVents so why not use the gui editor and create a dzvents script (module) with all the values and require that data inside your script?
In a script 'my-config':
	setting1 = 10,
	setting2 = 20
In a dzVents script:
	execute = function(dz, item)
		local config = require('my-config.lua')
		print(config.setting1)
or something like that. You can do all of this in domoticz gui.
emme
Post by emme »
This is EXACTLY what I was looking for :D :D
Thanks so much!!
dannybloe
Post by dannybloe »
Or better: add some config to global_data.helpers and you don’t have to use require at all. See the docs.
