iOS app: Homebridge for RaspberryPi
najtram
Domoticz version: v4.9700
Post by najtram »
Does someone had experience with this app: https://itunes.apple.com/nl/app/homebri ... 1123183713
I’m verry courious if this can also be used with an existing domoticz installation.
Please let me/us know! :D
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
Marci
Domoticz version: 3.8153
Re: iOS app: Homebridge for RaspberryPi
Post by Marci »
It's just a manager to allow you to setup, configure & add plugins to your homebridge server from iOS. Works fine with homebridge & homebridge plugins, therefore works fine with homebridge-edomoticz.
You'd still use your HomeKit app of choice to actually communicate with & control Domoticz. Your basically paying £5 for someone to set up homebridge for you if you don’t already have it installed, or (if you DO already have it installed), paying £5 to allow you to remote install other homebridge plugins without needing to SSH onto your server.
Bert84
Domoticz version: 4.10278
Post by Bert84 »
I bought the app, and it is working! I tried a lot of things to get the apple working with Domoticz, and this app is very easy to use. On your apple device you have to install Eve. I have 2 Raspberry PI’s. One with domoticz, and one with Homebridge for Raspberry PI.
bing69
Post by bing69 »
Have the app also purchased but I'm still not clear what action in or on the Domoticz Pi to do. Could you perhaps clarify that?
Bert84
Post by Bert84 »
There is nothing you have to do onthe Domoticz PI. On the Homebridge pi you log in tot the Domoticz pi (first install the domoticz plug in). On the the you can install Eve. Then in the app “woning” (in dutch) you can see al the domoticz swtiches.
