In the posted version there is no geographical filter but you can filter by Country, Province and city (or with some tweaking a radius around coordinates)
some of the used methods require dzVents 2.4.0 or higher
data from http://effis.jrc.ec.europa.eu
timer = { 'at every 30 minutes'},
httpResponses = { 'effis' } -- matches callback string below
execute = function(domoticz, triggerItem)
local sensor = domoticz.devices('Wildfire') --text or alert sensor
local currInfo = tostring(sensor.text)
if (triggerItem.isTimer) then
domoticz.openURL({
url = 'http://effis.jrc.ec.europa.eu/rest/2/burntareas/current/?limit=25&ordering=-firedate&format=json',
method = 'GET',
callback = 'effis'
--print('effis triggered by timer')
elseif (triggerItem.isHTTPResponse) then
local response = triggerItem
if not response.isJSON then print('data is not jSon') end
if (response.ok and response.isJSON) then
local ctry = tostring(response.json.results[1].countryful)
local vill = tostring(response.json.results[1].commune)
local prov = tostring(response.json.results[1].province)
local fech = tostring(response.json.results[1].firedate)
local superf = tostring(response.json.results[1].area_ha)
local dia = string.sub(fech, 9,10); local mes = string.sub(fech, 6,7); local anno = string.sub(fech, 1,4)
local humano = tostring(dia..'-'..mes..'-'..anno)
local mensaje = tostring(vill.. ', '..prov.. ', '..ctry.. '\n on '..humano..' area '..superf.. 'ha')
if mensaje ~= currInfo then
--uncomment line below and the commented end if you want to filter the results to match your location
--if string.find((string.lower(FIELD_TO_FILTER_HERE)), "[SEARCHSTRING_IN_LOWERCASE]") then
sensor.updateAlertSensor(0, mensaje)
print('msg : '..mensaje)
-- when using the filter also uncomment the line below to close loop
--end
print('**effis failed to fetch info')
