IP Address Permanently Banned
- Marci
- Domoticz version: 3.8153
Afternoon - no probs accessing forums from home, but when I try from work I’m told my IP is permanently banned... which I find a little odd. Could an admin (@remb0 / @gizmocuz) drop me a PM so I can get my work’s range checked / unbanned please?
- Marci
Re: IP Address Permanently Banned
OK - something odd going on. Spent the last hour IP banned on my home IP address also... and now fine again?
- Marci
And now laptop says I'm permanently IP banned, yet phone works fine... both on same wifi / public IP.
- jvdz
- Domoticz version: 4.107
Some sort of filter in your home router that prohibits the site for a specific device?
Jos
Jos
- remb0
ofcourse pm on the way
simonrg
- Domoticz version: 3.8807
Monday / Tuesday this week I had similar problems "IP permanently banned" on all devices on both of my home IP addresses, but ok via VPN into work.
I emailed info, Rob let me know he could see nothing on the server and this morning all IP addresses are working ok (thanks), except I now seem to have to log in whenever I refresh the forum, no idea what has changed.
I would be interested to know what caused the issue.
I do tend to leave the forum open on multiple devices, I assume this isn't an issue.
Thanks, Simon
Thanks, Simon
mathieumdejong
- Domoticz version: 4.10717
After being hacked last week and being infected I was blocked by internet provider last Friday.
Over the weekend I found the source of the problems being my raspberry pi with Domoticz. By shutting down and setting up a clean installation was the right precaution for my provider and he granted me access again on Monday.
I am now working on a clean installation of Domoticz and was going to consult the domoticz wiki pages for the steps to take.
I found out that I do not have access to Domoticz.com (error 520) and after consulting my provider I found out that he was not involved. I do have normal access when I use my mobile with 4g connection.
I expect that my home op-address is banned (blacklisted) by domoticz.com.
How can I be removed from this blacklist? Due to this situation I am currently not able to set up my raspberry pi with domoticz.
Who can help (pm please for further info)
Mathieu de Jong
Mathieu de Jong
mathieumdejong
I received a PM but I seems to be unable to reply !??
What is going wrong?
gordonb3
- Domoticz version: Custom
You're reputation is regarded as too low by the forum software because you are a new member. This is to protect us from being individually spammed by bots.mathieumdejong wrote: Wednesday 08 January 2020 12:28 I received a PM but I seems to be unable to reply !??
With regard to your IP being blocked, this site is hosted through Cloudflare and you may find some useful information to fix your issue in the following links:
